Question about Philips TP3284C 32" TV
Only get 2 channels plus a blank av1 and av2
I have a philips magnavox tv, smart plus eries model number tp3284c101 and I only get 2 stations now that it is not plugged unto cable. It runs through the stations on intitial set up but never gives me more choices. Right bow I have channel 5 and 6 with two black screens on av1 and av2. What can I do to get more channels?
  • Anonymous Jan 31, 2009
    same problem-how do i get channels on from cable hookup
  • 50 Answers
U can up grade ur ariel,use manal instal, or get freeview,freesat or sky
Posted on Jan 25, 2009
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
My audio and my picture are on two different channels like i can see the movei on av1 but i cant hear it but if i turn to av2 i can hear it but not see it
sir, check the cable which is connects TV and DVD player Audio Video cable ... both should locate at AV1 port in TV and DVD... else AV2
Mar 04, 2011 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do i change from av1 to av2 . . .av3 ? have remote . .
I think you can do channel down, or up, 'til you go below channel 2, or above channel 125. Then it toggles through external inputs.
Apr 18, 2010 | Philips 27PT6441 27" TV
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Jul 10, 2009 | Philips 32PW6506 32" TV
#27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Apr 30, 2009 | Philips Televison & Video
Phillips magnavox smart plus Model TP3284C101
if there is a DTV label on it , then it is digital .check the manual
digital would have the following : atsc ,hdtv ,digital tuner ,dtv
Jan 02, 2009 | Philips TP3284C 32" TV
Philips magnavox plasma tv model 42mf7010/17
Turn off the video mute if it has this setting. Try using a VCR tuner and connect the VCR to the TV on AV1 or AV2 inputs. THis fix is free until Feb. 09. After that, you will need a DTV converter box or pay for a cable/sat box.
Jul 14, 2008 | Philips 42PF9630A 42 in. Plasma Television
Red bar across top of screen??
I had the same horizontal, solid red bar along the top of the tv screen. I have an older analog Philips Magnavox TP2785C221. It just started all of a sudden. It was on every channel. However, the bar did not appear on the other input channels (e.g., AV1, AV2). So this meant that the red bar was only occurring on the antenna input. I unplugged my cable decoder box and restarted it. The red bar went away and that seemed to solve the problem for now.
Jun 25, 2008 | Philips Magnavox 42MF521D/37 Television
Philips TP3284C 32" TV Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
