Question about Olympus WS-110 Digital Voice Recorder
Remaining recording time VERY short for no apparent reason
For some reason, my WS 110 is showing that I have only a little more that 2 hours left of recording time. But I'm supposed to have something like 17 hours. What is this? I've erased all the files, but I still get only 2 hours of recording time remaining.
  • 1 more comment
  • juliemariefo Feb 03, 2009
    My WS-100 used to record for over 4 hours. Now, it records less than 2. The thing is, there are no files in any of the folders. When I right-click and open 'properties', it says that half of the 70 megs are used up. Huh? Can I reformat it somehow?
  • Anonymous Apr 28, 2009
    There appear to be no files at all, yet I cannot record because there is no time remaining.
  • frannyor May 04, 2009
    There are no files in any of the folders, but I have just 7 seconds of recording time. I just changed the recording mode from stereo HQ to HQ. I could not make the terminal changes suggested in OSX; "permission denied."
  • 8 Answers
Check how many different folders you have set up. just because you erase all in one folder, there can be other folders.
Find the manual reset for reformatting the recorder.
Posted on Jan 26, 2009
I had the same problem. The problem is that there are hidden files in the WS-110 flash disk. Connect the recorder to a PC, and delete the hidden files.
If using a Mac with OSX, open a terminal and type the following commands:
cd /Volumes/WS_110/
rm -rf *
rm -rf .*
Then close the terminal, and eject the drive. That will fix it.
It should be very similar from Linux - not sure how to delete hidden files from Windows, but there has to be a way, maybe you can change the folder's properties to see all files..
Good luck-
Carlos
Posted on May 04, 2009
  • earl301
    earl301 Jan 25, 2012
    DANGER!!!! This is a VERY RISKY PROCEDURE. Proceed with EXTREME CAUTION!! If you don't know what you are doing, you could accidentally erase all of your data from your hard drive.
    I had this problem and I simply erased the folders while it was connected to my Mac and that did the trick. Don't use the terminal for this.
Limited recording time
WS-100: 64 MB
HQ mode: Approx. 4 hours 20 minutes
SP mode: Approx. 8 hours 40 minutes
LP mode: Approx. 27 hours 20 minutes
You can go to the menu of the device and change the recording mode from HQ to SP to get longer recording time. Page 7 of the instructions explains how to change this.
Mar 19, 2009 | Olympus WS-100 Digital Voice Recorder
Won't turn on
It seems to be working now....I am keeping my fingers crossed. Being that my technology skills leave something to be desired, I fixed it the old fashioned way. Took the batteries out, blew hard into the battery space, put the battery back in and said a little prayer. It turned right on....
Jan 04, 2009 | Olympus WS-110 Digital Voice Recorder
Olympus digital recorder WS 110, keeps saying connect to pc
the only thing left to try is to try and format the device and see if you can restore it back to factory default settings. You go to the menu and to the format option. This will permanently remove any recordings you have done and as I said restore the device back to factory settings. If that doesn't work then you will probably need to send it to Olympus for repair service.
Dec 04, 2008 | Olympus VN-3100PC Digital Voice Recorder
WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Nov 28, 2008 | Olympus WS-110 Digital Voice Recorder
Silent left speaker of desktop stereo speaker system
The speaker probably belw out after many hours of playing time, if it is fairly new, try calling customer service.
Apr 27, 2008 | Video Game Consoles & Games
Recording Time
I have one of these recorders, I actually have 4 or 5, since discontinued I believe, and one is stuck at 43 min remaining.
I think that problems start when you remove the battery while
the recorder is / was in the process of recording (or in play mode) I now press stop while recording before opening the battery case to switch a battery
Mar 04, 2008 | Olympus WS-100 Digital Voice Recorder
Erasing Files
when you copy the files to your computer the files are still in the ws-100, you have to erase them in the ws-100 buttons after that.
Feb 29, 2008 | Olympus WS-100 Digital Voice Recorder
Only recording 59 minutes in LP mode
My WS-recorder did something simular to me. I hadnt used it for a while then it would only hold about 20 min. of recording no matter what record mode I selected.....so..... I held down the menu/folder button to get to the menu "mode". Press the FF to scroll through until you get to "FORMAT". Press Play and the screen will show "NO"...press FF to chose "Yes" it will ask you "are you sure" press FF to say "YES" then play to make it reformat. It hangs out for a couple of seconds then after that I have my regular 4 hours of record time back. ***** I would make sure I had downloaded all my info off the WS-100 BEFORE I did a re-Format.**** I dont know why it worked, but it did. I like this little recorder and Im glad to have it functioning properly again. The tinny/echoey sound could just be the environment you are in. Even how close or far it is from the subject...how many people are in the room....if a fan is on in the room....This little thing isnt super high quality in its play back mode....hook it up to you computer speakers and you will like the sound much better. Good Luck.
Jul 22, 2007 | Olympus WS-100 Digital Voice Recorder
Olympus WS-110  Digital Voice Recorder Logo
224 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
