Question about General Electric Ge Seer Light Extended Controller - Holter Monitor Recorder Controller -
HOW TO CHANGE THE TIME ON A GE SEER CONTROLLER
Set date and time
while the Seer Light Extend Controller is off, Hold the up button. While holding the up button, press the power button and release. When the power comes on the screen should be in set-up mode.
Jan 21, 2013 | General Electric Ge Seer Light Extended...
We have a model ubha-17j10nuca evaporator .we are installing a 12 seer condensor unit and they sent a KIT RXCTCHKM3306 TO CHANGE PISTON FEED TO A EXPANSION VALVE TO MAKE OLD 10 SEER UPGRADE TO 12 SEER ....
liquid line to inlet of txv. outlet of txv to inlet of evaporator. outlet of evaporator to suction line. does txv have a equializing line? strap bulb to outlet of evaporator, at either 11 oclock or one oclock and insulate bulb.
Apr 26, 2011 | Ruud Heating & Cooling
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
How do I get my tv on video without changing the code every time
it is unclear what you are trying to say, other than that you are trying to change input from cable to video? there should be either an tv input button on controller or on tv itself,. if you are using a universal remote, make sure it is programed for all devices per switch/button on universal controller. try www.manualsonline.com with make and model of controller.
Oct 17, 2010 | GE 27GT270 TV
No water from dispenser
As you have ICE then the most likely a fault with the water dispenser valve. It may also be a fault with the controller board. You can try resetting the Fridge Freezer by switching off the mains line power for approx 30 minutes and not opening the doors pr pressing any buttons during that time. Then turn the power back on and see if the fault has cleared. If not then you will need the valve or controller replaced.
Oct 15, 2009 | GE GSS20IEP Side by Side Refrigerator
I have a GE model No. BTN 748A100A1 (central air outside unit). Serial number 40564128. When was it made? What is its efficiency? It now handles #1950 sq. ft. Cab it handle 2950 sq ft when I remodel?
GE stopped making AC units probably 20 years ago. The same unit will not handle an additional 1000 sq. ft. I believe it is a four ton unit and about a 6 SEER rating which is way down on the efficency scale. You will need a 5 ton system to handle 2950 sq. ft. The average SEER rating now is 13.5.
Oct 07, 2009 | GE Heating & Cooling
Just had the haier 4 ton 13 seer outside unit installed. my inside unit is a payne and still in good condition.had a 4 ton 10 seer outside unit previously. my problem is the unit froze up the first night...
Your problem is that your 13 seer outdoor unit is not compatible with your 10 seer indoor unit, even though the tonnage is the same. The metering device on 13 seer indoor units is different. Most 10 seer indoor units do not have an expansion valve. When you change from a 10 seer outdoor unit to a 13 seer outdoor unit, you must, at the very least, change the from a fixed-orfice metering device to an expansion valve.
Jul 31, 2009 | Haier HC48C1VAR Central Air Conditioner
If installing a GSC140481 condensor with a ARUF486016 air handler is it necessary to change the txv to increase energy efficiency? Can these 2 units acheive a 14 SEER rating?
The real question is, am I going to get 14 seer using the old coil with the new condencer.If it is using r-22 then the old txv should work,but the old coil is proboby rated at 10 seer . since these were never tested together you would probobly see a minimal gain in efficency.Now if it is a matched set(ahri rated) you with definently get you 14 seer.Hope that helps!
Jul 09, 2009 | Goodman Heating & Cooling
General Electric Ge Seer Light Extended Controller - Holter Monitor Recorder Controller - Logo
246 people viewed this question
Top General Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a General Electric Health and Beauty Expert? Answer questions, earn points and help others
