Kenmore 110.91554210 won't fill for wash buzzes in wash
My washer won't fill for wash, buzzes when put in wash cycle. It will fill for rinse and spin out .
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
May 27, 2009 | Kenmore Washing Machines
Front load kenmore washer model 417 will not enter any wash cycle. It will do the rinse and spin cycle but not a wash
will it fill with water? if not listen by the water hose when you press start to wash and see if you hear a faint buzz/humming sound. If so you need to replace the water inlet valve. cheers
Mar 25, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
My series 600 kenmore will not wash all others work
if washer has speed switch could be it but if not lean washer back and look for loose connection on motor first if cks ok suspect timer wash contacts bad
Dec 07, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
