Question about GE 31GT660 TV
Ge 31gt660 tv
Ge 31gt660 unable to change video input to play xbox
  • jeanneebenne Jan 26, 2009
    yes i have the original remote. we have not had any problems with the tv other than we are unable to get the video games to work. I don't have the owners manual to see if there is a setting that needs to be changed or not. your help would be greatly appreciated
    Thank you
  • May 11, 2010
    Do you have the original remote (or an RCA branded universal replacement)? Or this is a case where you no longer have a video input available (the set doesn't offer you that option now, even though it used to)? Have you noticed occasional picture jumping, shrinking on the screen, or sometimes the channel just gets snowy and then clears up?
I had the same issue, turns out all I had to do was change the channel to 00, then my games or whatever I hooked up to the component inputs in the back worked like a champ.
Hope that helps.
Posted on May 24, 2009
The crapy part is that you have to go to walgreen, walmart, or frys, and get a swith converter if the remote will not let you go between the video in put it cuase it has been erased unless you can find a good universal remote with the tv/video or input switch on it this is how i have had to do it!!!! im buyin a 50 in lcd next week cuase this just pissed me off!!!! lol....
Posted on Mar 07, 2009
My Old 1997 GE 31GT660 was working just fine yesterday with a PS2. My girlfriend moved it today while cleaning and now I cannot get the PS2 to work. We have no remote but a friend used a universal to get...
Ur girl friend clean around did she unplug the tv.Replug it back later?Bet u she did,that why the tv universal codes is gone.Reprogram ur tv unverisal codes again should solved this problems.Tries push the manual control button channel up like one or two times tv will be in input video again like video 1 or 2.
Jan 13, 2011 | GE 31GT660 TV
Cannot change from video mode as we have no remote. We have a GE TV model 31gt660 which was hooked up by Direct TV. However, when the boys decided to hook up a flat screen to watch the fights the GE was...
My only suggestion would be to purchase a multi-functional remote that you could program to your TV. Now some remotes have to be programed buy your old remote. That is not what you need. You need the kind that comes with a little book that will list your tv model number and give you a code (usually 4 numbers) to teach it to talk to your tv.
Sep 20, 2010 | GE 31GT660 TV
Can't change input to play Xbox without clicker. With tv clicker I could access channel 00, which allowed me to play xbox. now the clicker is broke and I can't access channel 00. can i do this through...
The only way is with the remote. Try to find a GE or RCA universal remote. These remotes are designed around GE and RCA tv's and generally don't have to be programmed. (GE and RCA are both THOMSON made sets). Thanks
Oct 13, 2009 | GE 31GT660 TV
Unable to switch to Aux in order to play xbox 360
http://books.jvcservice.com/Download/566962143/LCT1467-001A-A.pdf
at JVC Support Page , download owners manual , listed above , on page 35 , it appears you should press INPUT button and cycle thru TV / video 1 / video 2 / V2 component / and video .
depending what video input option you used to hook up your Xbox to , you should be able to figure it out from here.
Dec 26, 2008 | JVC TM-2703SU 27" TV
I cannot find out how to switch it to the video mode
usually if you change the channel doen pass channel 2 then it will come across the different inputs. otherwise is there an input button on your remote? if so then push that button until you get the input you want.
Dec 18, 2008 | GE 31GT660 TV
Help
use tv/video or input button to switch to av input
May 07, 2008 | GE 31GT660 TV
Video input
If there is no input button on the tv itself to change the input then you will most likly need a remote. so you can get a universal remote and follow the instructions to adapt it to your set then you can use it to change the input. (you can get a universasl remote for like 10$) hope it helped
Aug 24, 2007 | GE 31GT660 TV
GE 31GT660 picture is intensly WHITE
The GE (actually RCA) 31GT660 uses the CTC187 series chassis. This chassis is notorious for bad solder joints on the shields around the tuner and microprocessor. When the solder joints on the shields crack, the microprocessor and EPROM lose their ground and the EPROM's data becomes corrupt. The solder joints on the shields will all have to be resoldered and the EPROM reprogrammed or replaced by a qualified tech familiar with the 187 series chassis.
Aug 22, 2007 | GE 31GT660 TV
GE tv modle 31gt660
have tech repair your tv the video circuit or related circuit is defected.good luck.
Jun 03, 2007 | GE 31GT660 TV
GE 31GT660 TV Logo
469 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
