Contact the authorized service center for Samsung. They can provide you the correct USB update. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
because plug ins are vital for some web site to operate that mostly occurs if you are on a web site that has videos ,but you should always check your plugin before agreeing to install ,the most common plugins are adobe flash player and shock wave player,so in summation it is vital to know your plug ins as some plug ins can cause major system malfunction but installing spy ware maleware trojans and fake alerts so trust plugins only from reputable sources
Main board fault.engineer says not worth fixing.sourced board and replaced myself cost me £50 but have seen it priced at £63 and £86 .got mine by phoning Beko spares. took 10 days tho.as not in stock
A U2, is normally caused by the toner cartridge not communicating with the main board.
Try removing and re installing the cartridge a few times.
If that doesn't work try replacing it with a new cartridge.
The memory may have dumped also. In that case a new memory or main board would be required.
The problem is in the main board of the monitor, so it should be changed or the flash chip on it should be re flashed with the dump taken from another same model working monitor. So this must be done in a work shop.
