Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony wow/Trusurround tv picture in picture will not turn of model KV-36FV310
  • 4234 Answers
SOURCE: Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Posted on Oct 02, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Posted on Dec 12, 2008
  • 30 Answers
SOURCE: My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Posted on Feb 07, 2009
  • 8457 Answers
SOURCE: KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Posted on Aug 25, 2009
Testimonial: "Thank you so much"
gopakumarg43
  • 74666 Answers
SOURCE: Sony Trinitron Wow/TruSurround manual
Hello
Get into this link where you can download your TVs maual for free. If you feel any difficuty in downlaoding the same, inform me by FixYa comment box. I'll send you a copy of it to you by return mail. OK
www.retrevo.com > Sony Manuals > Sony TV Manuals
Posted on Jun 15, 2011
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
CRT sony tv
Likely to be Capacitors in the power supply, Getting Baggy or maybe have blown tops or check bottom burst as well, upgrade with higher voltage if possible
Jan 16, 2014 | Televison & Video
My tv wont turn on ,It seem it is going to turn on and close itself
Searching for tv turns off but will turn right back?
  • Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Nov 26, 2012 | Sony FD Trinitron WEGA KV-29LS35 29" TV
I have a sony bravia and its not turnin on the red light its blinkin twice
2 Red Blinking lights on this model indicate an Over Current Protection status. This could be caused by a faulty power supply inside the TV or possibly by the Flyback Transformer.
This is repairable, but needs to be serviced by a TV service technician.
-Ben
Sep 13, 2011 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Sony Trinitron Wow/TruSurround manual japan
Hello
Jun 15, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony 32" xbr trinitron trusurround T V picture is black
Most likely on a trinitron tube if it is dark is the high voltage capacitor has blown. This is the device that feed the 30,000 or so volts to charge the tube, it attaches at the back with a clip and ****** and a single cable coming from it.
You can check easily if it is definately that as you will notice if you power the tv on and off once or twice if you get that static charge feel from the screen, if there is none there then almost certainly that is the problem.
Mar 10, 2010 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
The picture is greenish
chances are you have a bad tube or bad Video IC on the CRT board that connects to Tube! Look on your CRT Board and replace the video IC first.
Dec 30, 2009 | Televison & Video
Hello, I have a Sony FD Trinitron WEGA #KV-36FV310 manufactured around 03'-04', all of a sudden lately i've noticed a ghosting blue line spiraling up the screen,i only notice it when the screen gets dark,...
It's the return of the line, it should be cut off completely. To make it invisible again the cutoff point for the blue cannon should be adjusted (practically this means - turn a potentiometer) - all it takes is a screwdriver and the necessary knowledge. How much it will cost - that depends on how expensive your repairmen are
Dec 04, 2009 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Tv takes a minute to get picture
Greg , Sounds like a bad "jungle IC" but without knowing specific voltages it`s really hard to say, picture should show up in approximately 15 seconds not a full minute, it`s normal for the audio to be heard almost instantly way ahead of the video, part number for the IC is 875210104, generic number is cxa2154as, be prepared they are not cheap IC`s, I would probably run the set for awhile and see if it gets worse as time goes by. good luck
Nov 27, 2007 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
