Question about Sharp Xe-a21s Electronic Pos Cash Register
Print size is to large - Sharp Xe-a21s Electronic Pos Cash Register
Hto increase print size
You have to change print size by choosing a larger font in the software you used to produce the document.
Oct 08, 2014 | HP Officejet 6500 AllInOne InkJet Printer
Mirror image properties
I think your image size is too large. when you command your printer to print the image. choose the paper size on which you want to print it.operating system will automatically set the image size to the paper size
Dec 06, 2013 | HP Officejet H470 InkJet Printer
When printing incoming hotmail message, the subject line is printed in very large & bold letters
Click on the 'print' icon to display a print compatible version, then print. If the problem still exists, use google chrome to change the html code of the text to manually change text size
Oct 19, 2012 | Microsoft Computers & Internet
Increase font size
Print is so small? Are you talking about on a piece of paper you printed out that it is small? If so what program did you use to print it? If it's a document in something like Microsoft Word, you just highlight the text and increase the Font Size.
If you are talking about the fonts on the screen and webpages being small you can Right Click on an open space on the desktop and select Properties to get the Display to open. Or you can click Start/Control Panel and look for Display or Appearance and Personalization. Open the display then select the Appearance tab and change the Font Size. It can be Normal, Large or Extra Large.
May 14, 2012 | Computers & Internet
Make larger prints on HP printer
If your printer support printing from large prints.
Large print jobs can be printed by selecting the properties button, when printing then selecting the desired printer size (sometime in the paper tab)
Oct 03, 2011 | Microsoft Windows XP Professional
When i go on line to print my pictures it says i have low resolution. how do i change that on my camera?
If I knew what camera and model the answer would be a lot easier but, let me explain what happens.
Most pocket point and shooter type cameras and all DSLR's have an image quality selection menu.
Go to your manual and look for image quality, your camera is most likely set on the smallest size which might be okay for internet use but not printing. What you need to do is take this to the maximum size your camera can produce most I've worked with say "L" for Large or "Fine".
Now what else will happen is the memory card will not be able to hold as many pictures on Large as it did on "s" or small. Just an example if you card said you can take 1000 pictures on its setting and you change that to Large you may only get 200, but those 200 will be able to be printed. The final print size then would depending on the Megapixel size of your camera.
Dec 23, 2010 | Cameras
The print job in the print queue is preventing other print jobs from printing im receiving this error message i have a hp c 4580 printer
If one job isn't printing, cancel it, and let the other one's print. I read somewhere there is a 2GB limit on print spool jobs...and if you reach that limit, everything locks up. I am not sure on it...but if you have a realy large document, either print it alone, well, just print it alone. Try to spool your print jobs from the smallest ones first, and don't overload it. The is especially true of printing pictures...because if you don't resize them, they can be especially large files (and large pictures) sometimes you don't realize that what you are viewing on screen is only 26% of the actual picture size...especially if you have say, a 8MP or higher camera pixel size capability.
Jan 13, 2010 | HP Photosmart C4580 All-in-One InkJet...
Size of the item is too large
Print acts according to settings in print properties
Dec 16, 2009 | Roxio PhotoSuite 7 Platinum for PC
How to increase the size of the print? Print is too small
Right click on web page, choose select-all. Right click again click print preview, goto top tool bar and click full view (mouse over icon), then choose Custom from the Change Print Size drop-down menu. Specify how large you would like the webpage to be printed by setting a percentage in the Custom Size text box. This will enlarge the printed size of the entire webpage, but it might result in some of the webpage being cut off on the printed document. Usually you have more than one page to print. This is one way, maybe someone else can give a better way. Good luck.
Jul 18, 2009 | Lexmark C533DN InkJet Printer
Mismatch paper size error
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print
on the bottom of that screen there should be a scale to paper size drop down box. Scroll to the bottom and your saved name and dimensions should be there.
You will have to setup each individual sized template ones and then just scale to fit each time. Hope this helps
Mar 26, 2009 | HP Photosmart C4480 All-In-One InkJet...
Sharp Xe-a21s Electronic Pos Cash Register Logo
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
