Question about ASUS Eee PC 1000H Laptop
Want to change physical keys
I've switched the functions of my shift and up arrow keys. I want to physically swap the keys. Is there a way to do this? i don't want to break anything. Thanks.
How to find inverse of log in a casio 991ms calci?
The inverse of the natural logarithm (in base e) is the EXPONENTIAL function (e^x). It shares the same physical key as the LN function. One is accessed directly and the other through the SHIFT key. The inverse of the logarithm in base 10 is the function 10^x. Both functions share the same physical key as described above.
More generally if y=log(in base b) of x =log_b(x) then x=b^(y). The base must of course be a non-zero positive number.
Aug 25, 2011 | Casio FX-115ES Scientific Calculator
How do I work the anti log on TI-30X 2s? Where are the buttons?
What you call the antilog is also known as as the power function. More specifically, the inverse of a decimal log is the function 10 to a power, (10^x) It shares the same physical key as the log function. If the calculator has a key marked [LOG] you have to press the [2nd or SHIFT] key followed by the [LOG] key to activate the anti-log.
For natural log (logarithms in base e) the antilog is the exponential function (e^x). It shares the same physical key as the [LN] function.
May 09, 2011 | Texas Instruments TI-30XA Calculator
How to find ln (inverse log function) in casio calculater
The inverse function of the natural log (ln) is the exponential function (e^x). They share the same physical key. One is direct access key and the other is the shifted one: You have to press [SHIFT] to enable it.
Feb 09, 2011 | Casio FX-300MS Calculator
How to use antilog by casio fx-82es
The inverse of the log function is the function 10^
antilogarithm of (x)=10^(x)
The function shares the same physical key as the [LOG] function. To access it you press [SHIFT][LOG].
The antilogarithm of the natural log [LN] is the exponential function [e^x]. It shares the same physical key with the [LN] function. To access it press [SHIFT][LN]
Aug 29, 2010 | Casio FX-300MS Calculator
I need an inverse log button on the casio calculator 9750GII.... does it have one??? I know how to do log, but can't find the inverse.
The log base 10 function has an inverse: It is the 10 ^x function. It shares the same physical key with the decimal log. Use [SHIFT][LOG].
The natural log (LN) has an inverse alos and that it the exponentila function e^x. It shares the same physical key with it.
Jul 20, 2010 | Casio FX-9750GPlus Calculator
How to do inverse of tan cos sin
The inverse trigonometric function share each the same physical key with its direct function. The inverse trigonometric functions are accessed with the [SHIFT] key
[SHIFT] [SIN] accesses the arcsine
[SHIFT][COS] accesses the arccosine
and [SHIFT][TAN] the arctangent.
Apr 14, 2010 | Casio FX-9750GPlus Calculator
How to do inverse log on a casio fx 9750g plus
The inverse of a natural logarithm (ln) is the exponetial (e^x). Both share the same physical key [LN] pour ln and [SHIFT] [LN] (e^x) for the exponential.
Syntax is : [ln] 3 [EXE] gives 1.098612289
exponential of 4: [SHIFT][LN] 4 [=] 54.59815003
The inverse of decimmal logarith is raise 10 to a power. Both share tha same physical key [LOG]
log of 6 : [log] 6 [=] result is 0.7781512504
antilog of 0.77: [SHIFT][LOG] 0.77 [=] result is 5.888436554
For more complicated arguments (expressions) it may be a good idea to use parentheses to enclose the arguments of functions.
Mar 29, 2010 | Casio FX-9750GPlus Calculator
I cant find my volumen keys on my acer aspire 5517
The physical volume keys on many laptops are either represented in the function keys (e.g. F1, F2, etc.) or sometimes in the arrow keys (on some Acers).
To use the keys, you need to press the blue [Fn] key (that is usually by the CTRL key) and then press the volume key on the function/arrow key to increase or decrease volume. There should also be a mute key that can be used similarly.
Feb 10, 2010 | Apevia Acer Aspire AS6530-5514 Laptop
Lamp reset timer
Hi there
There is basically two ways to reset the lamp timer :
1. ) On the Projector's physical buttons
Arrow Keys - Up , Down , Left , Right then Menu and Enter - this should be done quickly whilst the Projector is in standby mode.
2.) Switch Projector on - Hold in the Up Arrow Key on the physical buttons on the Projector untill a PIP screen appears - then just follow the on screen steps.
Sep 25, 2008 | LG RD-JT91 Multimedia Projector
Up arrow key sticks
This fix also works for the LX 710 Cordless! Yay! Thank you.
Nov 14, 2007 | Logitech Cordless Desktop MX3200 Laser...
ASUS Eee PC 1000H Laptop Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
