Question about EliteGroup ESC P4VMM2D Main Board Socket 478 for Intel Pentium 4 processor (MBECP4VMM2D) Motherboard
Connecting USB harness to mother board
I am trying to reinstall a p4vmm2 mother board into my computer but some of the harnesses are not marked clearly as to where they need to go. In particular there are 2 usb headers with 9 terminals on each, (pin 9 is missing on both usb1 and usb2.)
Both will accept a harness, consisting of 4 individual plugs. The plugs are identified and their wires are color coded as follows;
Vcc 1 red
gnd1 black
Data - 1 yellow
Data +1 green
The other wires are similarly identified with the number 2 used instead of 1. My question is, what are the pin numbers on the USB headers that these wires should be connected to ??
Thanks Tibor
  • tib389 Jan 26, 2009
    Thanks for your help, I got the ports wired properly, now I am looking at the bias supply that used to work, but now I get no outputs from any of the supplies.
    Tibor
Look on page 23 of the motherboard manual. Download it from here:
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=413&areaid=2&LanID=0
Posted on Jan 26, 2009
  • locob Feb 12, 2009
    What do you mean when you say "bias supply"?
How to remove the wiring harnesses from their connectors on the 42" Olevia TV
Exactly what harness are you trying to remove?...are you referring to the flat ones that go from the TCON to the panel? or the ones that connect the power supply to mother board
Aug 02, 2017 | Olevia Televison & Video
No power to inside on/off switch 120v or 12v, i checked with multi meeter
You either have a bad harness from the main board to the eyebrow board or the eyebrow board is bad. You can open the freezer door and snap the upper cover off of the refrigerator which will expose the harness. The harness will be secured to the back of the eyebrow board with a small plastic band and a screw. you can either disconnect the harness and tie/tape a string to the harness which will allow you to reinstall the harness after testing or you can make a long jumper that will connect to the harness and allow you to test the continuity without removing the harness. Either way you need to check the harness for continuity and also verify that there aren't any shorted wires. If the harness checks good, then it is probably a bad upper circuit board (eyebrow board).
Apr 09, 2014 | Dometic Refrigerators
Usb problems
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question exclamation mark? ! or a red X you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Aug 20, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
This is the 2nd time this happened. First time cpu shut clear down would not boot up. Mother board was replaced about 18 months ago. Now the same area under the mouse pad got super hot and all the USB...
try cleaning your computer of dust using a fine air blower from a compressor making sure that there is no MOISTURE in the air line specifically around the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
the usb
control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
also
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
hope this helps
Jan 05, 2011 | Computers & Internet
I have the Nordictrack C2500, and for the second time the main board double beats when trying to start it. You press a button for speed, incline, the fan, anything and it double beats and won't start. The...
You have a wire harness that attaches the upper board to the lower board. You may have to pull that harness thru the uprights ( Attach a fishing line so you can either pull a new harness thru or the original one ) and inspect it for snags crimps or broken wires also use a meter to a continuity check on the harness ends. Since the the command signals travel thru this harness also check all connections on the lower board. Its starting point
Jun 10, 2010 | Nordic Track NordicTrack Treadmill, A2550
P4vmm2 mother board problem
I download it from the manufacturer site
Mar 24, 2009 | ASUS Computers & Internet
Wiring up power
You can download the manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Jan 31, 2008 | EliteGroup P4VMM2 Motherboard
EliteGroup ESC P4VMM2D Main Board Socket 478 for Intel Pentium 4 processor (MBECP4VMM2D) Motherboard Logo
320 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
