Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Tv problem 10801 hdtv samsung
Every once in a while the tv will go off for 5 secs then turn back on.. I notice the red timer light on the front of the tv lights up during this process. Now the tv does not come on at all manually or with the remote.. I had the convergence board replaced 4 months ago...I have a TV repair man coming on tuesday but was wondering is there anything I can do to fix myself. I already checked the fuse in the back of the tv near the power cable...It is Fine!
  • Anonymous Mar 31, 2014
    I know the tv is getting power I was wondering if it may be a blown fuse.
I do not have a solution but was curious what your repairman said...
Posted on Dec 27, 2007
SOURCE:
Hl-s4266w Powers on for about 15 seconds then turns off. Was told it is a timer that needs to be turned off by using factory remote - I have lost the remote! now what?
Not sure about the timer. Our 55" samsung broke last week and it was shutting on/off no picture just turn on music recycling off/on. The blue light was lite on TV and red light to the right was blinking. The TV repair guy replace the Power Supply board b/c of swollen capacitors, was under warranty. The board runs about 70 bucks though. Took him all of 5 mins after unscrewing the back cover of TV. The board is at the bottom center after cover is removed. Hope this helps
Mar 18, 2010 | Samsung HL-S4266W 42" HDTV
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Replaced the bulb on a 50ML8105D/17, the bulb starts to light but turns off at 5 seconds and the red led light on the front comes on.
Hi,try to reset lamp timer by unplugging tv wait 5 min and plug it back again.Check for clicking sounds it could be the ballast which is the board that powers the lamp that it could be bad.God bless you!
Oct 06, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
May 27, 2009 | Samsung HLN617W 61" Rear Projection HDTV
My xbox 360 has no picture but sound only no red lights green ok
First take off my hard drive on the 360. Then plug it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) because it will not work for HDTV setting . then plugit into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on take 1 towel fold it long ways and wraped it around 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. if you still have problem you can now can send it to get repaired since there is a 3 year warrenty for red ringed 360's.
Feb 15, 2009 | Microsoft Xbox 360 Console
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
362 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
