Question about Cub Cadet Garden
I NEED A WIRING SCHEMATIC FOR SOLENOID LTX 1045 CUB CADET
I DISCONNECTED THE SOLENOID TO REPLACE IT AND IT IS STILL IS NOT WORKING. I WANT TO CHECK TO MAKE SURE THAT I HAVE IT CONNECTED PROPERLY.
  • 109 Answers
SOURCE: cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
Posted on May 03, 2009
  • 13 Answers
SOURCE: I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Posted on Apr 16, 2010
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
Fix4You
  • 32 Answers
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Posted on Nov 14, 2010
leo81369
SOURCE: I need a wiring schematic
Ipodaptor
Posted on Apr 29, 2011
LTX 1045. Where can I get a wiring diagram or wiring information?
Hi do a search on Google. Type in. cub cadet LTX 1045 wiring diagram. GOOD LUCK
Apr 04, 2016 | Cub Cadet Garden
Will a wiring harness from a ltx 1045 fit a ltx 1050
Since the LTX1050 has an electric PTO and the LTX 1045 has a manual PTO then I would say no.
May 10, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
2000 Kia Sportage where running but disconnect the battery now it want start
Try this:
Make sure the positive cable, makes a good connection at the battery and at the starter. Make sure the negative cable makes a good ground connection at the battery and (preferably) at the engine.
  • Check the battery the simple way, like this:
Turn on the headlights, then try to start the car.If the headlights do not dim or go out, then the battery is likely ok.
  • Check the starter and solenoid:
If the wiring looks ok, then look at the starter solenoid for a good connection, and proper voltage at the starter(10 volts minimum while cranking).
If the starter spins and no crank, the problem is most likely the Solenoid's bendix gear is stuck.
Have someone hit (not too hard) the starter while you try to start the car. This usually works by dislodging a stuck bendix gear.
  • Make a simple test of the alternator:
If you can, somehow get the engine running, measure the voltage at the battery. It should be at least 13.6 volts to properly charge the battery.
Apr 18, 2015 | 2000 Kia Sportage
My 2002 Pontiac Bonneville won't start all I get is a clicking noise when I turn the key
First thing to do is to test the battery. Do this by turning on the lights or radio and then try starting it. If the battery is weak when you try to start it the lights will dim or go out completely. If so replace the battery. If the lights stay bright the problem is probably in the solenoid or starter itself. The clicking you are hearing should be the solenoid on the starter trying to engage and most likely doesn't have enough power in the battery to start the car. If you are not mechanical or don't have the right tools you will have to find someone to replace the starter and solenoid. If you end up only changing the battery make sure to hook battery jumper cables or a battery charger to the cable connections to retain power to the car when you remove the battery. This is so your radio doesn't have to be reset by entering the code to the radio. If you don't have a charger or jumper cables, then make sure you have the radio code to reset your radio before disconnecting your battery or you will be disappointed when the new battery goes in and your radio keeps asking for you to enter the code and it won't work.
Oct 28, 2014 | 2002 Pontiac Bonneville
Car won't crank over.
Are you sure you have all wires on Starter and Alt, Have you checked fuses for fuel pump, check starter relay, Reason for changing Starter and Alt??? DID YOU DISCONNECT BATTERY BEFORE YOU STARTED REPLACING PARTS???
Dec 13, 2013 | 2005 Ford F-150
Disconnected battery in 2007 gmc Yukon. Dash lights and radio work. Engine won't crank. Remote won't work. How to reset?????
kindly pls check the BCM which is located under the left side of the dashboared i hope that will help.
Mar 30, 2013 | 2007 GMC Yukon
Garden Logo
102 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
