Question about JVC KD-S590 CD Player
STOP WORKING AND WONT COME BACK ON
II CHECK FUSES AND CONNECTIONS JUST WONT TURN ON
What could cause my ODB2 connector to stop working?
It's got to be another connector or fuse someplace. The OBD II connector does supply power to the reader and one of the very likely sources of failure is the fuse for that power. My GF's GMC Yukon XL OBD II connector didn't work and it turned out that the power was on the same fuse as...the cigarette lighter. She knew her son-in-law had caused the lighter to stop working but it never occurred to her that there would be any side effects.
You should be able to find the wiring diagrams online or get a copy from the dealer (especially since he cannot find the problem) and trace back from the OBD II connector to the fuse and power source to identify the fuse in question. Of course, if it appears good, check it with a meter--they can blow in spots you can't see.
Apr 02, 2015 | 2007 Honda Fit Sport Hatchback
Bose CD player wont turn it on at all
Plug it into another wall socket, try it there. Then turn off all lights in room and plug it in, see if you can see any glow or LED inside it or outside. Then check the fuse in the plug if there is one.
Dec 15, 2013 | Bose 3 2 1 GS Series II DVD Home...
:I shorted out my kdc 128 head unit and i switched all the fuses but it still wont turn on. any ideas?
Firstly, the main wires from the KDC-128 you need to check are:
RED - this should be connected to the vehicle's +12v IGNITION wire.
YELLOW - this should be connected to the vehicle's =12v BATTERY wire.
EARTH - i) some tuners will only earth when the tuner itself, is screwed into the vehicle's chassis (i.e. a metal mounting bracket); ii) some tuners require the BLACK wire to be attached to the vehicle's chassis (i.e. a metal mounting bracket).
Secondly, if the above wires are connected correctly, then you should suspect the fuse on rear of the tuner has blown (even if it LOOKS ok). Replace and see what happens.
Thirdly, if all above are ok, then you have a short somewhere on the vehicle.
Jan 12, 2013 | Kenwood KDC-128 CD Player
Both my turn signals and emergency flashers stopped working
hi...
there is a relay which connects turn indicator and the emergency flashers which is provided for the timing of the flash.this timer relay may got burnt or damaged. even though the fuses are OK the turn indicators wont work. please check this.
please rate me weather the information which i provided was usefukll to you by clicking on the thumbs present on the end of your page.thank you
Jul 09, 2010 | 1999 Ford F350 Regular Cab
Help
You will need to check for any blown fuses or tripped circuit breakers. Electric dryers should have the wiring checked at the terminal block to make sure that the connection is good, or to verify that the connection is burnt out.
If the power is there, you have to check the door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 17, 2010 | Frigidaire GLEQ332A Electric Dryer
My washer stopped in the middle- and wont turn back on- full of water right before the spin cycle! I have checked the breaker, unplugged it, pulled the knob and tried to recycle it- NOTHING! it is only 7...
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 19, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Motor just stopped working
make sure you get 230 volts at light connection or 115 if your in america. if yes check internal wiring. if all connections look good go to switch on wall where its switched on. check is there power on common side of switch. if yes then switch it on and check is there power on load side of switch. (L1). if no then switch is broke. replace switch.
Dec 29, 2009 | Hampton Bay 52 In.Carriage House II in...
Stop lamps wont work 93 ford explorer
is it a seperate fuse ??
if its not the fuse check that the wires are connected ok!
Is there power at the switch ??
Jul 17, 2009 | 1996 Ford Explorer
1997 Mazda Protege LX 1.5
replace the fuses and check all the wire connections unter the dash by the pedals and under the hood if that doesnt work get your computer checked
Apr 02, 2009 | 1997 Mazda Protege
JVC KD-S590 CD Player Logo
49 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
