Question about Dell Inspiron 2200 Notebook
Cannot connect to wireless
I have a Dell Inspiron 2200
Dell Wireless 1370 WLAN Mini PCI Card
I've never had a problem connecting to wireless before. Recently I tried connecting to my new network and although it said: 'connected, signal strength very good' it also said 'acquiring address'. Thus, I could not get on the internet.
I believe I had to change the IP address. So I looked at my roommate's computer and found the IP address. It was 192.168.1.1 But my computer also asked for a 'subset mask' and 'default gateway'. I googled this IP address and got some numbers for these things. Clearly I have no idea what I'm doing.
SO, usually, to get the wireless internet going, I click on Start>Run> then hit okay because when I open 'Run' there was always something already written in the blank. When I did this I got a list of programs. I would then click on Wireless Internet, it would say Stopped, and I would hit Start, and it would work, hooray!
So after all my fiddling with IP addresses, I restarted my computer and first went to Start>Run> but it was blank! It gives me the option to type something in or browse, but I have no idea how to restore what was usually there so I can restart my wireless. So now I'm in really bad shape.
Hope this information will allow someone to help me. I am not to familiar with this stuff but am doing the best I can.
Thank you!
  • therlihy209 Jan 26, 2009
    Okay. I did that, but now I'm back to where I started. I was originally on the automatic settings and the wireless connection was saying 'incorrect IP address". I was unable to fully connect. It said connected and acquiring address.
    Regardless of that, I cannot access the possible connections. Usually when you click on wireless it gives you a list of networks to choose from. Well right now it says "Wireless cannot configure this wireless connection". Usually what I do is go to Start>Run> Then simply press okay. (There is something already written in the box). This brings me to a window listing a bunch of programs (?) I'd scroll down to wireless, select it, then press start to get it doing. BUT, I can't do that anymore! The box is blank under 'Run'. I don't know what was originally there and I don't know why it disappeared. It has simply made my problem worse than it already was.
  • Dell Master
  • 32,281 Answers
You have changed your TCP/IP settings and it cannot communicate with your wireless router.
Open the Control Panel, Click on Network Connections, then right click on Wireless Network Connection, then scroll down and click on to highlight Internet Protocol (TCP/IP), then click on the Properties button.
Select (click on) Obtain an IP address automatically
Select (click on) Obtain DNS server address automatically
Click OK and close and shutdown and reboot Windows
You should now be able to access the Internet
Posted on Jan 26, 2009
  • Chris Hingee
    Chris Hingee Jan 26, 2009
    The next thing to check is the wireless router's wireless configuration.
    Do you know how the wireless router is configured, does it have encryption enabled if so is it WEP or WAP or WAP2 and the encryption key?
    Do you know the SSID?
    Do you know if MAC address filtering is enabled, if so is the MAC address of your Wireless card been added to the wireless router's configuration?
    Do you know the IP configuration address of the wireless router, if so can you ping that address and get a reply?
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
My wireless connection is not working on my inspiron,what should i do?
Cheapest steps first, getting more progressively expensive as the list progresses:
1) Upgrade the BIOS for the system, available at support.dell.com
2) Upgrade the chipset drivers to the latest version, same website.
3) Upgrade the wireless card drivers to the latest version, same website.
4) Re-set the wireless antennas. Usually you can access the WLAN mini-PCI card at the bottom of the systems. It will have two small wires connected to it, one white and one black wire.
5) Re-seat the wireless card. It's like a large RAM SO-DIMM chip, snap-in and out.
6) Perform a system restore (hopefully it doesn't come to that)
7) Re-install windows
More expensive:
8) Replace the WLAN card.
9) Replace the system board.
Apr 19, 2011 | Dell Inspiron Mini Nickelodeon PC Notebook
How do i download network adapter for my dell tower, its service tag is C0WST21
please page the URL below in your browser and click download button.
http://download.cnet.com/Network-Dell-Wireless-US-WLAN-Network-Adapter-Card-Wireless-1370-802-11-b-g-WLAN-MiniPCI-Card-Wireless-1350-802-11b-g-WLAN-miniPCI-Card-Wireless-1450-802-11a-b-g-Dual-Band-WLAN-miniPCI-Card-Wireless-1350-WLAN-802-11b-g-PC-Card-TrueMobile-14/3000-2112_4-109107.html
Feb 19, 2011 | Dell 04U852 Network Adapter
My laptop won't connect wireless with my internet after I formatted it. Is this driver related? Dell latitude 120L. If it is, how do I fix it? Thanks!
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=Dell+latitude+120L&rpp=12&p=1&subcat=dyd%2f1005&rf=all&nk=f&sort=K&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=anav
go here
download wireless drivers
Dell Wireless 1350 WLAN MiniPCI Card, Wireless 1450 WLAN miniPCI Card, Wireless 1350 WLAN PC Card, Wireless (Except US,Japan) WLAN Card, Wi... Download this driver if you reside outside the United States and Japan. This release supports the Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card, MiniPCI and PC Card devices (not USB). R140745.EXE Hard-Drive 52 MB Verify Operating System and Product Compatibility
Oct 09, 2009 | Dell Latitude 120L Notebook
Dell Inspiron B130--I have an internal Broadcom 1370 Wireless mini pci card installed. When installed the card everything worked. I had to reformat and reinstal WinXP from the hidden partition using...
Check Device manager to see if the wireless card is Enabled and working. If it has a yellow ? against it then reinstall the wireless PCI LAN driver.
Jul 08, 2009 | Dell Inspiron B130 Notebook
Wireless connection
hi,
welcome to fixya.com
yes offcourse ur dell inspiron 5100 laptop support wireless connection,and it will detect the wireless connection in ur computer,uninstall and reinstall the wireless driver and then try and connect to wireless connection,and what u can do is that reset the router and then try and connect to wireless network it will definately connect..and it will also detect the wireless signal also........good luck
pls rate this solution its a request..pls
Feb 11, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
Acquiring Network Address
reset the modem and the wireless router by powering them off for 30-60 seconds, then plug power back in. Wait a minute or so for the devices to reset then go to the PC and try to connect again
Good luck
Jan 26, 2009 | Dell Inspiron 2200 Notebook
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
May 29, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 2200 Notebook Logo
241 people viewed this question
Alun Cox
