Question about HP ProLiant ML350 (370507R001) Server
After initial power on of HP ProLiant ML350, it will not stay on.
I have had the HP ProLiant ML350 for a couple of years with no problems until now. After recently moving the unit, I plugged in the unit then powered on but the system does not stay on. It starts off as if it is going through its power-on cycle then just shuts down. The unit has been moved before without any problems.
  • 339 Answers
Is it on a dedicated circuit? Have you checked the voltage? As a control, I would suggest you move it back to its most recent location temporarily or at the very least to a location with a different power circuit to try to isolate if you have a power issue or a server failure.
Do you have two power supplies? If so, be sure they are plugged into independent circuits if at all possible.
Posted on Jul 12, 2009
Server no display when power on
Can you confirm that server fan is rotating or not when server power on. and which led glowing red when you power on server
Mar 15, 2014 | HP Compaq ProLiant ML350 G3 Server
Hp Proliant ML350 g4 will not power on. System was on but not responding so used power button to shut down. Now no response to pressing power button. No LEDs lit anywhere. Fans running on power supplies.
sounds like the motherboard has gone.... you could try changing the PSU and popping out some of the ram boards to see if that helps. but with the symptoms you've said, i'd say its the motherboard.
Oct 28, 2013 | HP ProLiant ML350 G4 Server
I need Network card (LAN) driver for HP Proliant ML350 5G server.
Go the website of HP, chose for the support and drivers - lookout for drivers and software - enter your product name i.e HP Proliant ML350 5G Server and click on search.
You will get the list, select your product. Select the operating system you are using on your server - then choose the driver type - click suitable, from the list of drivers and download it.
Apr 23, 2013 | HP ProLiant ML350 G5 Server
HP Proliant server 350 halts with LED 2 and 3 Orange
Open the case. Power up and look for internal LED that corresponds with warning light number 2 on main board.
Number 3 is power.
Dec 05, 2012 | HP Compaq ProLiant ML350 G3 Server
Need help with Proliant Dual XEOn ML350 G3. Front
Sounds like the power supply has gone bad on some outputs - most likely the 3.3 volt source.
Jun 07, 2010 | HP (302203-001) Motherboard
ITS NOT LOADING WINDOWS
If it is not booting at all then the disks will not be configured. Better boot the server using the HP utility CD and install the OS after creating the right array and partitions.
Jan 04, 2010 | HP Compaq ProLiant ML350 G3 Server
Hp proliant ml350 g5 vga drivers for windows 2000 professional
Download the latest Proliant Support Pack from HP's web site. This will update the drivers for everything on the server at once.
Just go to hp.com and click the link for "Support & Drivers" at the top, then click the radio button to download drivers and enter ML350 into the text box. Select the G5 from the list and then select your OS. The PSP will be near the bottom of the page. The display driver will be close to the top if you just want to update it.
Apr 08, 2009 | HP ProLiant ML350 G5 Server
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
Computers & Internet Logo
196 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
