Question about 4113LX 1Button Remote Start System with Unlocking
Parking lights flash 5 times why wont the car start?
99 Park ave wont start security light flashing
leave car in run position till light stops flashing takes mine around ten minutes when stops turn key all the way off then should start right up happens to a lot of GM vehicles and mine does it all the time
Mar 08, 2014 | Cars & Trucks
Why are parking lights flashing 5 times at startup
Replaced electronic module ?????? Which electrical module ? Did you have the vehicle check for DTC'S - diagnostic trouble code's ? Not engine OBD2 code's ,but the body control system modules . FEM - front electronic module , REM - rear electronic module plus the instrument cluster ! The main light switch is an input to the istrument cluster . Everything is done by computer , input from main light switch for park lamp activation or headlamps ,running light's etc.. to the instrument cluster . The instrument cluster has a microprocessor inside ,with logic . The I/C will send a message over the SCP serial data communication bus to the other modules ,and the one the message is intended for will read it an turn on the light's or what ever the message tell's it to.
The park light's flash when ? Opening the doors , when starting the vehicle ????? Content theft system function ? do the horns sound too ?
Dec 15, 2017 | 2002 Ford Thunderbird
Have 2002 regal 200k miles bought it used a couple of months ago was driving along ,came to a stop engine died . .Now when you turn the key the dash lights flash and wont start. car will start if you...
Look under the dash by the parking brake and try to see if any wires are being moved or chafed by the parking brake linkages. That is what I have found in the past.
Jul 17, 2012 | 2002 Buick Regal
My 2007 silverado was fine when i parked it last nite..now it wont start..plenty of battery and lights..but no ignition..and the steering wheel is not locked when in park..it will not start in park, or...
The steering wheel will not "lock" until you turn it about 45 degrees from center...this is normal. If your security light is flashing, there is a problem with your security system that is keeping you from starting the engine. Try this: Set the parking brake. Turn the ignition to the "RUN" position and wait about 10 minutes for the security light to stop flashing. When the light stops flashing, crank the engine without turning the key to the off position. If it starts, take the vehicle to get the security system checked. If it doesn't start, tow it. You probably need a new PassKey sensor.
Feb 22, 2011 | 2007 Chevrolet Silverado 1500HD
First of all. We have put 2 new starters on this car recently. We thought the first might have been a fluke. However we had the 2nd checked and it tested fine as did the battery and alternator. Problem is...
what do you mean by wont start?? engine cranks but wont run? engine wont crank? Is the anti-theft light flashing? is the car in park? did you put it in Neutral and try to crank it?
Nov 19, 2010 | 1992 Saturn SL
My truck won't start. The security light flashes and won't go off. I have changed my fuses out, but the security light still flashes instead of staying on for 5 seconds. What else do I need to try?
Looks like the TDM in the security system (VATS/PassKey) is having problems, it can get worse till the car wont start anymore. You can find a great write-up here: http://newrockies.ca , it was the only thing that saved my Park Avenue.
Oct 17, 2009 | 2000 Chevrolet Tahoe
No air conditioning, flashing climate light
You should make sure you have proper charge for sure.has your battery gone dead lately? I know on some of them digital climate controls will act exactly like this and have to be reset or go through a setup sequence.
Aug 13, 2009 | 1994 Buick Park Avenue
Car wont start
could possibly be a flat battery possible could be the starter motor also when you unlock the car with the key the immobilizer should of disarm
Jan 27, 2009 | 2003 Mazda Mazda6
Dodge Ram Truck wont shift into park or reverse
The parking pin inside the transmission has sheared and is interfering with reverse as well. I would locate a reputable transmission shop.
Jan 05, 2009 | 1999 Dodge Ram 2500 4WD
Timer in auto start.
if it is the 2000 rs the manual can be downloaded from scytek.net
1. Turn on ignition.
2. Within 5 seconds, press the valet switch 5 times.
· The parking lights will provide three blinks, indicating that you have entered Programming.
3. Press the valet switch 12 times (engine run time)
· The parking lights will flash each time the valet switch is pressed.
4. Within 5 seconds, press the transmitter button corresponding to the desired time ( left button 15 min, right button 25 min)
· The parking lights will flash to indicate the setting.
1 flash = 15 min
2 flashes = 25 min
5. When you are finished, turn off the ignition to save the changes.
all of this is based on that it is the galaxy 2000rs m,
Nov 19, 2008 | Scytek 2000RS-M Remote Control
4113LX 1Button Remote Start System with Unlocking Logo
194 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
