Question about Refrigerators
Refrigerator goes into and sticks in "auto defrost" mode
The motor will stop running and everything in the freezer and fridge starts to warm up. I have found that if I unplug the refrigerator for 30 seconds and then plug it in again, it starts working again. This happens about two or three times a week. Why does it go into the "auto defrost" mode -- assuming that's my problem -- and how can I prevent it from doing that? Or how can I get it to go back on by itself without my having to unplug it? Thank you!
  • 1462 Answers
SOURCE: Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Posted on Jun 22, 2007
  • 198 Answers
SOURCE: GE Profile Fridge/Freezer defrosting
You will need to replace the electronic mother board which is located in the back of the refrigerator,Inside rectangular cover near the bottom left.
Posted on Feb 28, 2009
  • 531 Answers
SOURCE: Refrigerator warm and defrost heat sheath and coil frozen solid
check see if you have frost build up in freezer could be the heater or defrost thermostart or timer board call service
Posted on Apr 07, 2009
  • 9 Answers
SOURCE: Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Posted on Aug 22, 2009
  • 193 Answers
SOURCE: I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Posted on Apr 23, 2010
Freezer is warming- up to 24 degrees now. something is running- should i unplug the freezer to keep the defrost fan from coming on until repairs can be made?
the fan is not a defrost fan? it helps to circulate the cold air into fridge and freezer. so when the fridge goes into defrost mode the fan and compressor stop running. if ur getting constant warm or heat? I suspect ur defrost timer is not coming out of defrost cycle? the heat is only suppose to last up to 20-30 minutes then back into cold mode? hers a trick u can use that may get u back into cold mode, locate the defrost timer in ur fridge usually at top center. then under the timer u will see a tiny slot or hole. if u stick a small screw driver into that hole and turn slowly clockwise till u hear it click? if its stuck in defrost , it will now come out of defrost and u should hear the fan and the compressor come on, hope this helps let me knoiw if u have any more questions
Mar 16, 2015 | Refrigerators
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
Fridge stops working and warms up for half a day then will cool back off and start working for a day or a few days. When it warms up everything in the freezer defrosts but will then refreeze a day later...
Check your defrost thermostat in your freezer access panel. Your defrost timer could be faulty, Your defrost timers ussually run for 12 hours and defrost runs for 30 minutes. That being said that is why I believe your timer is getting stuck on run and then eventually it finally gets unstuck and goes into defrost. Eventually it will get stuck in one place or another.
Aug 27, 2010 | Frigidaire FRS26H5AS Side by Side...
My frigidaire gallery FRS26ZSH refrige side is not working but the freezer seems to be keeping things cold... the fan motor is running, is this a compressor problem? help
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 15, 2009 | Refrigerators
Amana Bottom Freezer 7 years old running but not cold.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover inside the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
heavy frost-
Aug 25, 2009 | Refrigerators
GE Eterna ESS25LGNA freezer side not working
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Feb 28, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
The outside metal around the freezer area is very warm.
We were informed that because of a lot of power outages and surges that the freezer was in constant defrost mode. Since the freezer had been in constant defrost for at least 5 days, we were told that the condenser would probably short out. Even though the fridge was 7 years new. We decided it would be cheaper in the long run to get a newer more energy efficient one, because we didn't know what other damage had been done and if fixing everything would just be too expensive and it could quit before everything was fixed.
Sep 13, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Jun 21, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
