Question about Epson EMP-S5 Projector
Why does my infocus x2 projector have rainbow color on it
I have two dlp infocus X2 projectors. Both of them have lost their color. Is there something I can do to fix it?
This could be one of 2 things. It could have a bad color wheel or there is a setting problem in the unit. If the video mode is not set correctly like NTS or PAL it can give a black and white image.
The other could be your color wheel has failed. Did the unit make any noises before the color went out?
Some times the color wheels will make noises when the age before they crack or break from the heat.
I believen you can pull the lamp out and with the lamp out try and power the unit up, look into the little hole the lamp shines into and see the color wheel spinning. when you first plug it in and unplug it the wheel should spin and you should see the colors change. DONT TOUCH THE COLOR WHEEL they are fragile and can break easy. Some get more brittle over time from the heat of the lamp.
May 19, 2010 | Compaq MP2800 Microportable Projector sps...
X2 projector A somewhat irregular vertical line has appeared near the middle. A slight rainbow affect at the line, right of the line gets progresively darker. The blank screen is normal. The projector is...
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Mar 12, 2010 | InFocus SP-LAMP-018 Projector Lamp for X2,...
Need help looking for the part.
Hi:
Seems you broke the part called the color wheel assembly. Usually the color wheel can be replaced by you or a qualified TV servicer.
Mar 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
Need replacement color wheel for 3300MP, where can I purchase one?
I had the same issue and it is impossible to find a new one and Dell is extremely expensive on repairs. You need to find a used Dell on Ebay or an Infocus X2. The X2 has the same color the only catch is that there is black timing marker on the motor that is the wrong position for the Dell projectors. I was able to compare the broken one to the new one and moved it to the proper position and everything worked fine. There are a lot more X2 projectors out there on Ebay.
Aug 03, 2009 | Dell 3300MP Multimedia Projector
Doest function.no image projection,fun does not function
fuse on ac filter board. if that's ok, there is a power supply issue.
May 31, 2009 | InFocus PROJECTOR LAMP, Projector Lamp FOR...
Loud huming noise and vibrations from infocus x2 unit.
the berings on the colorwheel are failing. i suggest replacing it. also, the discoloration is baked-on dust. the wheel can be cleaned, but it's no recomended, due to the finish on the glass and the fact that the heat has probably weakened the glue holding the glass on the wheel. it's the same glue holding the light tunnel together, and it's collapse is probably causing the faint image. the parts aren't all that expensive, but you can only get them through an infocus authorized service center. check the website for one.
Apr 30, 2009 | InFocus SP-LAMP-018 Projector Lamp for X2,...
Infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Sep 01, 2008 | InFocus X1 Multimedia Projector
Infocus x2 dose nothing
Assuming the power outlet and cable is OK the most likely problem is the power supply and needs to be replaced.
Dec 06, 2007 | InFocus X1 Multimedia Projector
Epson EMP-S5 Projector Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
