Question about Saeco Primea Cappuccino Ring Coffee Maker
Saeco primera ring wont grind coffee
Wont grind the coffee but sounds like its grinding
  • 70 Answers
SOURCE: Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
Posted on May 22, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
Posted on Jun 03, 2009
EsWorld
  • 1618 Answers
SOURCE: Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Posted on Jun 04, 2009
  • 1089 Answers
SOURCE: My Saeco magic grinds the beans, but no coffee
HI
When a machine grinds but doesn't make any coffee there are a couple of things.
If the grounds are wet in the dredge drawer, then you have a plugged brew head and need to clean it.
If the grounds are dumped dry into the dredge drawer, then you have an overcharge and need to adjust the dosing lever back from the full charge. On your machine it is inside the door at the top center. Pull the lever back towards the front 1 click. Then try again.
Posted on Nov 14, 2009
SOURCE: Saeco Giro Plus Bean Grinder Section Inoperative
i am facing the same problem. Please let me know if you can fix it. Thanks.
Posted on Nov 24, 2009
Saeco primera ring, will not grind coffee, high piched sound as if there are no coffee beans to grind. Its also indicates out of coffee and of course there is coffee bean the hopper in it.
Sounds like the grind is too fine and the beans are not able to get to the burrs, try adjusting 2-3 numbers coarser. Remember only adjust when the grinder is running.
Jun 08, 2012 | Saeco Coffee Makers & Espresso Machines
Coffee grinds but nothing comes out of dispensing head. Brew group wont come out.
I have the exact same problem and haven't found any replies to your request. Did you finally find a solution to the problem? Thanks
Dec 11, 2011 | Saeco Odea Giro Plus Coffee Maker
Saeco Vienna. Wet cofffee grinds in the dump box.
It could be the grind on the coffee or the red group o-ring and the 2 o-rings on the white plastic valve need to be replaced.
Nov 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco digital plus not grinding
Sounds like your grinder is clogged and do you hear a clack, clack? That would be the solenoid opening the doser box.
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Coarse Grind
il y a de l'eau qui passe en dessous du plateau avec du café moulu
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Primea Cappuccino Ring Coffee Maker Logo
26 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
