Malber P21 Front Load Washer
Problem for Malber P21 Front Load Washer
Malber doesn't even turn on.
By l_raimondi on Jan 25, 2009
Hello,   This is an email I got from  my tenant in NYC about the Malber I bought for the apartment for them about one year ago.
"Laura,
I was finally abot to get George and Petrit (building maintenance guy) up to the apartment to look at the Malber.  They checked the water supply and the electrical supply, and all is OK on that end.  However, the Malber is not working at all.  No lights, no power, nothing.  I did work once or twice when we used it in the fall, but it hasn't worked now for several months.
George says he had nothing to do with ordering or installing the machine.  There were no instructions or warranty with the machine when we took possession of the apartment, so I don't know where you got it or what the situation is.  I had to track down the instructions via an Internet search.
Looks like this is in your lap now.  Let me know if I can be of any help."
Can you help me?
Best Solution
posted on Mar 16, 2009
Very Helpful)
Gearmeister
Rank: Guide
Rating: 91%, 16 votes
Clight16 is very likely to be correct. I repair Malbers (in the Wash. D.C. area) and have found door switches to cause these symptoms 90% of the time. BUT, that doesn't necessarily mean replacing the switch. Here's how to test: First, check out the little square hole where the door latch (on door) fits into the machine. You'll see a white plastic "frame", and behind it, a black plastic piece that slides to the right. We'll be sliding that "slider" a little later. OK. Turn machine off (if it's been on). Wait about 2 mins until "safety latch" disengages. (Don't force handle - it can break!). Open door. Set top right knob to "Off" position. Press "Start" button (power on). Turn top right knob to "Beginning of wash cycle". Because door is open, nothing happens - yet. Finally, using a small screwdriver, or other thin object, slide that black plastic "slider" over to the right (about 1/4 inch). Don't be afraid. There is nothing anywhere back there that you can hurt - or that can hurt you. It's totally safe! That simulates the door closing and the metal latch forcing the slider over. My hunch is, the machine will start working (filling with water). If so. you have a simple (and free) fix. The problem is: the metal latch is not forcing the "slider" over to the right far enough. To fix: You need to "allow" the latch to move a little further to the right. To do this, you'll enlarge the hole (on the back of the door) the latch protrudes through. The square hole is sized to stop the spring-loaded latch in the exact right spot. Press the latch back, and file (or scrape) away a little plastic on one side of that little square hole - so when you release the latch, it snaps over a bit farther than it did before. You only need the latch to "lean" over a LITTLE farther (1/16") so only remove 1/32" of plastic. That should do it. And may God bless.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 26, 2009
Not Rated)
clight16
Rank: Wiz
Rating: 83%, 73 votes
Sounds like a door switch.
Was this helpful?
Yes
No
Popular Solutions for Malber P21 Front Load Washer
Questions and Unsolved Problems for Malber P21 Front Load Washer
Do you recommend Malber P21 Front Load Washer?
Answer
Answer
I need the belt for malber T39 were can i find.
Answer
HI I have a Malber p21 easy automatic washing machine and its software is broken and i want to buy... (More)
Answer
The washer does not go into spin cycle for me. It starts to spin, rattles and rocks terribly, then... (More)
Answer
Believe i have a faulty selector switch have a new one but how do i remove the old one? does the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repairmen
in , AR
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
