Question about Parrot 7" PHOTO VIEWER BLUETOOTH® ENABLED DIGITAL PICTURE FRAME PV7RED
Reset parrot photo viewer 7 - Parrot 7" PHOTO VIEWER BLUETOOTH® ENABLED DIGITAL PICTURE FRAME PV7RED
Parrot ck3100 stuck on goodbye screen any way to reset it ,thank you
Found this on the net, not sure if it works or not:
"Hard reset the CK 3100 by pressing all three buttons for two seconds and then pressing them a second time (warning initializes factory settings)
2. hard reset thisback to factory settings"
Straight copy paste out of fixya website
and the link to the source:
Parrot CK3100 Bluetooth car kit hard reset
Oct 08, 2016 | Parrot SA Parrot Ck3100 Lcd Handsfree...
I purchased a Toshiba 500gb Canvio portable hard drive. I would like to access the User Manual on the hard drive, but when I attempt to do it, I get the message, "Windows Photo Viewer can't open this
It's Adobe to open so right click application you want to open and select reader Adobe...if not install download Adobe from website for free. What is happening it's defaulting to photo view you may not have software installed to read that file.
Always right click that file and another list will appear info about that file...
I hope this helped
Happy. New year!!!??
Jan 02, 2018 | Toshiba Canvio 500 GB USB 20 Portable...
How do i make microsoft office picture manager my default photo viewer on windows 7 starter?
if you right click on one of the photos select properties you will see what it opens with select change place a tick in the box always use this program to open these files a browse option might open if the photo viewer is not there
hope this helps
Jun 23, 2012 | Microsoft Computers & Internet
My friend was using Windows Photo Viewer, and now my desktop I can't open any icons, and when I do it says Windows Photo Viewer can't open this picture because either Photo Viewer doesn't...
There should be files type issue first make sure your photo image open in ms paint if it will open with mspaint then your photo file type is fine but if it will not open there then you need to check file type. For that go to control panel ->folder option then files type . Check that your photo file type will open with photo viewer then apply then check. If still same then need to repair photo viewer because it is corrupt. Let me know if you need further assistance. Thanks for using FixYa.
Aug 23, 2011 | Computers & Internet
How do I reset my computer to show pictures and images even cartoon character.
well to reset your system you will have to format your pc, by reinstalling the OS. or you can download the photo viewer software here-->http://photo-viewer.smartcode.com/
thanks for rating Good luck
Feb 06, 2011 | Computers & Internet
Installing coby digital keychain software
Start from scratch, uninstall everything and pretend your installing for first time:
1. have keychian unconnected from usb
2. install software
3. DONT RUN SOFTWARE YET
4. connect keychain to usb
5. on keychain select: USB update
6. Run software
7. well-ah, intelligence > poorly organized device - enjoy everyone
Dec 14, 2008 | Coby DP-5588 5.6-Inch (4:3) Clock &...
Coby Digital Photo Keychain DPKEY
Getting Started- VERSION DPKEY and 151SX
STEP-1
-INSTALL The Photo Viewer Software
Download & Install The Photo Viewer Software From Our Web Site:
The Driver CD files (Setup Guide, Manual and Photo Viewer Software) can be downloaded from
our web site. Click on the link below
http://www.cobyusa.com/?p=prod&prod_num_id=80&pcat_id=3001
NOTE:
Find your Photo Key Chain version and Download the Driver CD files along with all the latest
updates.
The version is listed on the back of the Photo Key Chain as 151SX, DPKEY or 151MP.
To Download & Install The Photo Viewer Software From Our
Web Site:
a) Create a folder
on your desktop before downloading the file from our website. To create
a folder on your desktop, go to your desktop and RIGHT click on your mouse. A set of
menus will appear. Select “New” and then “Folder” (you will notice a new folder will
appear on your desktop), give it a name, example DP151.
b) Click on the below link and select “Download”.
c) Click on your Photo Key Chain Version to start the Download. The version is listed on the
back of the Photo Key Chain (151SX, DPKEY or 151MP.
d)
After clicking on your version, you will prompt with a pop-up screen “Do you want to save
or open the file”. Select Save.
e) Another screen will prompt you to save the file on your computer. Save the file on your
“Desktop”, in the “DP151” folder and select “Save”.
f)
Once the download is completed, go to your desktop. Double-click on the DP151 folder.
g) To install the Photo Viewer software, Double-click on the Setup.exe file. Click NEXT on
all prompts.
h) After the installation. The Photo Viewer Software icon will appear on your desktop.
i) Done! ……Continue with “STEP- 2
STEP-2 CONNECT the Key Chain to your computer using the supplied USB cable. Upon
connecting the Key Chain to your computer, the Key Chain will prompt you to set the
device to “USB Charge or USB Update”. Select USB Update by pressing the Right
button and then the Middle button.
STEP-3 RUN the Photo Viewer Software to transfer photos to the Key Chain. Double-click on
the Photo Viewer icon located on your desktop. Once the Photo Viewer opens, it will
give you a message indicating “Upload Completed”. Click OK. (This message
indicated that the Photo Viewer Software has made connection with the Key Chain). If
you have received the “Upload Completed” Message, Skip STEP-4 and continue with
STEP-5
STEP-4 If you have NOT received the “Upload Completed” message, then you are
encountering the below error message:
Can’t Find any Photo Viewer, or
another program owns it. The
program will exit!
*Set the Photo Key Chain to USB update. SEE “STEP- 2”.
*Make sure the USB Cable is connected properly, you should hear a “clicking”
sound when the USB Cable is connected properly in the USB Port.
*The Key Chain should also appear under “MY COMPUTER” as a removable
disk. If not, switch the USB Port or replace the USB Cable.
STEP-5 LOCATE the images on your computer (See Diagram)
STEP-6 HIGHLIGHT the images files that will be transferred to the Key Chain (See
Diagram)
STEP-7 SEND the highlighted images to the Device Panel (See Diagram)
STEP-8 TRANSFER the images from the Collection panel to the Key Chain (See Diagram)
Disconnect the Key Chain from your computer. Done!
Nov 04, 2008 | Tao 1.5-inch Square Polished Silver Photo...
Parrot evolution
There is a tiny reset on the back of the parrot. Use a paperclip to depress and reset the device. This should remove any pairings.
Jun 20, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
My digital photo keychain album
My instruction booklet says:
IMPORTANT: The keychain MUST be plugged in and in "update" mode in order for you to open the Photo Viewer progarm. If it is not plugged in, or is in the wrong mode, you will get the following error" No photo viewer is found, program terminated!
2. Once the keychain is plugged in and in "update" mode double click the Photo Viewer icon on your desktop to launch the application. (I wasn't able to double click the Photo Viewer icon at all, so I don't know what else to do). And for the rest of you that are able to double click it, I will give you the instructions.
3. Use Photo Viewer's file manager to browse photos on your computer.
4. Once you select a photo, it will show up in the crop marquee. Put the box over the area that you want to see on your keychain and click the POST button (arrow to the right). This will move your photos to the collection panel.
5. Delete any unwanted photos by selecting the image in the collection panel and clicking the X button from the menu bar.
6. Once you have all photos in the collection panel that you want on your keychain, click the "synchronized" button. At the bottom of your screen, you will see that the status has changed from "idle " to "download" and the black bar will show %complete.
7. Once the download is 100% complete and you get the following message, "photo viewer data synchronized complete", click OK, exit the progam and disconnect the keychain.
IMPORTANT: Do not disconnect the Digital Photo Keychain until the download is complete and you exit the photo viewer software.
Jan 14, 2008 | Digital Products Monaco Ezcolor Photo...
Parrot 7" PHOTO VIEWER BLUETOOTH® ENABLED DIGITAL PICTURE FRAME PV7RED Logo
44 people viewed this question
Top Parrot Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Parrot Photography Expert? Answer questions, earn points and help others
