Question about Parallax Power Supply Parallax 7100 Series 55 Amp REPLACEMENT Electronic Power Center
Converter output less than 6 volts
Parallex 7100 with battery removed only puts out less than 6 volts
How to check alternator output
with engine running you should be able to check alternator output on the battery. put your leads on the positive and negative post and see if it reads more then 12 volts DC. usually charges at 13-13.5 volts
Apr 24, 2016 | 2005 Suzuki Boulevard C90
Why will my 390cc-4 not take a charge. Only 6 months old
If it has a nickel cadmium battery (NI-CAD) they tend to develop a memory when charged at a certain rate.For example: If you did not charge it fully ( at least 8-10 hours or whatever instructions noted) it can only go back to that level that you charged it at . On a scale from 1-10 , let's say the charge made it to 6 ,then you used it maybe until it died and then you put it back on the charger,it will then only go back to 6 or less because the undercharging cut half of the battery's life ,therefore causing it to die out quicker. It is possible your charger is also not performing.Look at the voltage output on shaver and check the output with a volt meter and see if it reaches the manufacturers rated output.If it does reach it then you have a bad battery and I don't know if you can replace that type of battery.I hope that this helped and good luck !
Feb 11, 2015 | Braun Series 3 390Cc-4 Rechargeable Foil...
Battery keeps going dead
24 volts is way to high, the battery should be 12 volts, the alternator should put out 13 volts up to 15.5 volts, if the alternator belt is excessively loose, it wont charge properly, if the belt is tight check the alternator output, (you can ck it at the battery) make sure the output is a minium of 13 should be not less when reving the engine up a little the voltage should increase, but not above 15.5 volts
Apr 12, 2014 | Cars & Trucks
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
Feb 06, 2013 | Sharper Image Audio Players & Recorders
I have a 02 dodge grand caravan sport with 0351,0352,0700 codes...car runs good then shakes and even stalls at times,but not all the time...i have replaced ignition coil,wires,plugs,and catalytic...
po700 code just means you have codes
P0351-IGNITION COIL #1 PRIMARY CIRCUIT
WHEN MONITORED
With battery voltage greater than 8 volts during engine cranking or greater than 13 volts with engine running. Engine RPM less than 3000. No coil in dwell during test.
SET CONDITION
Peak current is not achieved with battery based dwell plus 1.5 msec of diagnostic offset. It takes less than 3 seconds during cranking or up to 6 seconds while running to set.
POSSIBLE CAUSES
- Ignition coil
- Intermittent condition
- ASD relay output circuit
- Ignition coil driver circuit open
- Ignition coil driver circuit shorted to ground
- PCM
P0352-IGNITION COIL #2 PRIMARY CIRCUIT
TEST NOTE
This symptom is diagnosed using the test P0351-IGNITION COIL #1 PRIMARY CIRCUIT.
WHEN MONITORED
SET CONDITION
POSSIBLE CAUSES
- Ignition coil
- PCM
var classElements = new Array(); var node = document; var tag = 'a'; var els = node.getElementsByTagName(tag); var elsLen = els.length; var pattern = new RegExp("(^'\\s)specs_note(\\s'$)"); for (i = 0, j = 0; i
Jun 14, 2011 | 2002 Dodge Grand Caravan
Alternator out put and out put on automotive battery terminals ,what is the permissible difference in volts? What are the possible reasons for a reduced output on battery terminals (eventhough alternator...
New altenators will put out up to 14.7 volts. When they put out less than 12.0 it's time to replace them. Batteries should hold at least 12.0 volts, they wont hold much more than that.12.6 maybe.
If they will not hold at least 12 then they need replaced. Batteries go bad because one of the cells inside will not take a charge anymore.
Nov 23, 2010 | 2008 Mitsubishi Lancer GTS CVT Sedan
Battery light is on
More then likely alternator is bad, check voltage at battery with volt meter, should be reading no less then 13 volts, if less bad alternator, check with engine running, if you have to jump start, remove cable before checking voltage at battery, that voltage will be alternator output voltage.
Aug 05, 2010 | 1998 Toyota Tacoma
I have a 39 ford 6 volt battery operated car. I
you need a voltage doubler circuit which feeds from your 6V DC system and converts it to AC and steps it up and converts it to 12V DC. This device might be difficult to find. OR use a 6Vdc power inverter and just use a 120volt AC fan if much easier to source out in your area.
You might want to try a 12VDC high speed fan and see if the 50% reduced speed is already sufficient for you.
Aug 30, 2009 | 2001 Ford Escape
Parallax Power Supply Parallax 7100 Series 55 Amp REPLACEMENT Electronic Power Center Logo
90 people viewed this question
Top Parallax Power Supply Electronics - Others Experts
Are you a Parallax Power Supply Electronics - Other Expert? Answer questions, earn points and help others
