Question about Philips DVDR75 DVD Recorder
Blocked dvd tray
Product will record and play back but won't open tray, so dvd can't be changed. panel says 'blocked'. I cna't hear the mechanism working.
    Problem Solver:
  • 8 Answers
The disk inside is most likely jammed. It would be best to take it to a repairman, or you can try to remove it your self.
Posted on Sep 16, 2007
I have the same model, I use a utility blade or needlenose pliers and pry it open while
hitting 'open' It gets
blocked without a disc in it. Too bad, it's been a good recorder, maybe a 5 percent coaster rate.
Posted on Jan 10, 2008
SOURCE:
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
JVC DR-MV80B display says hello then shuts itself off.
On electric board you need to change the STR,and work fine.....
Sep 09, 2012 | JVC DR-MV80B DVD Recorder / VCR Combo
I have a JVC VCR/DVD-recorder, model DR-MV7S. It developed a problem... when you placed a DVD on the tray & pressed the "eject/open" button to take the DVD into the recorder, the tray...
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
Sep 19, 2011 | JVC DR-MV7S DVD Recorder/VCR
The tray on player won't stay closed therefore I can't play a dvd.HELP
It sounds like there is something inside the dvd player, that isn't supposed to be there, that is keeping the tray from retracting fully. Try unplugging the unit and gently turning it upside down and giving it a little shake. Not too hard. This might jar the item loose, you will hear it knocking around. If you do knock something loose turn the unit so the front is pointing up and let the foreign object fall to the back of the unit where it hopefully won't interfere with the operation of the mechanisms inside. If you don't hear something come loose, remove the screws on the bottom, sides and back of the unit to remove the top cover. Make sure you have unplugged the power before you do this. take a look and see if you can find something jammed in the track or the gears for the tray. If you do gently remove the item with your fingers or a pair of needle nose pliers. Once removed replace the cover and away you go. If there is nothing blocking the tray and the mechanism, you probably have a gear system to close the tray. At some point someone must have pulled fairly hard on the tray causing the gear teeth to jump, check and make sure they aren't damaged or stripped. You are going to have to them either remove one of the gears (or pull it up so it can turn without turning any other gears) push the tray back into the fully closed position and replace the gear. Once you have done this you will want to test to make sure the tray will function properly. Place the top cover back on, but don't secure it with the holding screws in case you need to open it back up again, plug the unit in and test the tray. If it works unplug it and secure all the screws for the cover and away you go. Otherwise you are going to have to play with the gears till it is back in the proper starting position. If your hearing some strange noises and its not working, then the gears are probably badly stripped. You can contact the manufacturer and see if they can sell you some spare parts or direct you to someone who can replace it. Though at this point simply replacing the unit may be less expensive.
Jul 26, 2011 | Zenith XBV243 DVD Player/VCR
My disc tray won't open the lights turn on and work but the disc tray just won't open. How can I fix this?
hi,
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
ok
May 05, 2011 | Cyberhome CH-DVD 300 DVD Player
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Daewoo S04 DVD won't open
The tray is blocked. Unplug and open the player's casing and check for any obstructions and remove it. It might be a disc or something. Check also the gear as you can hear the motor running but the tray don't open.moz-screenshot.png
Aug 23, 2009 | Daewoo DVRS04 DVD Recorder/VCR
LG DVD REcorder disc tray will not open
Most likely the tension band that is attached to the mechanical parts of motor and the tray detached. you'll need to disconnect the power and unscrew the cover open and put the band back in place.
May 21, 2009 | LG DR787T DVD Recorder
Philips DVDR75 DVD Recorder Logo
524 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
