Question about Jensen XA4100 Car Audio Amplifier
I have a Jensen XA4100 and i pluged the AV cables in the A-B side and have it on 4 channel but only the A-B output work...how do i get both the A-B and C-D to work at the same time? the
2 Suggested Answers
  • 113 Answers
SOURCE: Jensen XA4100
try using power directly from main to the remote terminal to see if headunit has a problem or the amp.please disconnect remote from head first.
Posted on Aug 22, 2007
Will there be interference if I hook a Jensen MDV6115 to a 120 volt tv?
Under no circumstances must you use a different voltage ! The power supply on these units are designed for 12v only.
However, if your question is simply referring to connecting the AV 'outputs' (i.e. yellow, red, white rca's) of your Jensen, to the AV 'inputs' of our TV, then that is fine. The AV outputs can be treated the same as any other video device.
Feb 07, 2013 | Jensen MDV6115
I get a weak or no signal message on my new Samsung plasma. I'm using coaxial to my cable box. The cable works fine because I can see the vcr when it plays. I have it set to cable on the right channel...
In this case, your VCR becomes the cable channels tuning device for your TV, the better connection should be from your cable box output to your antenna/cable TV input with the coaxial cable, surely, your TV has a better cable tuner than your VCR, to connect the VCR to TV you can use its AV outputs to an available AV inputs of your TV, you can get a better sound and picture in this way.
Mar 17, 2011 | Televison & Video
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Jan 01, 2011 | Hitachi C21-F200 21" TV
CAN I connect 2 tvs.to one converter box and how.
If you're using a box that has an RF (antenna) output on channel 3 or 4 to the TV, you can insert a splitter and feed two sets. A splitter looks like this:
It takes the signal in on the single connector side, and splits it between the two output jacks on the other side. You can find splitters at TV retailers, Radio Shack, and even at Home Depot or similar stores in the electrical section. Run a cable from each of the output jacks to the antenna connectors on the two TV sets. Each TV will need to be tuned to the converter box output channel, and both sets will get the same program (whatever channel you have selected on the converter).
If the converter box has audio and video output jacks and the nearest set has an AV input, you can connect that set with the same kind of cable you use to hook up a DVD player (RCA plugs on the ends) and select the AV input to see the converter box signal. You would run a cable from the RF output connector of the converter to the second set's antenna jack. Then you wouldn't need the splitter, and the set using the AV inputs would get better quality picture and sound. Again, each set will get the same program as determined by the converter.
Hope this is what you need to get going. Thanks for using Fixya!
Dec 17, 2010 | RCA Analog (RCA) to Digital (VGA)...
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
How many watts RMS are?
Hello melesk82,
The Jensen XA4150 is a 4-channel amp that outputs 75 watts times 4 channels into a 4 ohm impedance.
Hope this helps.
Oct 03, 2009 | Jensen XA4150 Car Audio Amplifier
LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
May 25, 2009 | Rio Go Video DDV9475 Dual Deck VCR
Dont know how to wire a subwoofer
The Jensen XS1010 is a 4-ohm sub and should work properly off of the outputs of most any single channel monoblock sub amp or off a bridged 2-channel. You did not say what brand or type of amp you intend to use, but in any case, there's only 2 wires to connect to the sub, one positive (+) , the other negative (-). Simply match them up with the positive and negative on the amp speaker output and you are ready to bump.
Here's the link to Jensen's website:
http://mobile.jensen.com/jensen/
I'd recommend downloading the XS1010 manual. They recommend an enclosure with at least .75 CuFt internal volume.
If this helps, please rate it as "FixYa". Thanks!
Mar 28, 2009 | Jensen XS-1010 Car Subwoofer
Should I use this Jensen LXA300 AMP to power my DS930 kicker 6x9's
i have a 2 channel boss amp running my 6x9's & a candence 2 channel on my bass ..they say for ur mids & high's a 4channel is best , but i like the 2 channel better ... so i think u wil be fine with the amp uhave , just be sure 2 tun it down so it wnt blow ur 6x9's...
Oct 02, 2008 | Jensen LXA300 Car Audio Amplifier
Jensen XA4100
Aug 18, 2007 | Jensen XA4100 Car Audio Amplifier
Jensen XA4100 Car Audio Amplifier Logo
18 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
