Question about Sony KP-51HW40 51" Rear Projection Television
Need to change crt's on a sony kp51hw40
Is there a written procedure for the replacement of the crt's
like what do you need to remove to get the tubes out
  • 4 more comments
  • markkoffman Jan 26, 2009
    The link is for lamp replacement
    I want to change crt's in a rear screen projector
    sony kp51hw40
    I am looking for a procedure on how to disassemble not just oh take the tube out and put in another
    I have the service manual, it is of no help
    are you researching this?
    now that is the kind of info I need. Sounds like you have been there.
    what about the hi voltage leads. Are they ok to just disconnect or do you need to ground them out first?
    anyone else care to give advice on crt removal from?
    Brigadier General:
  • 8,619 Answers
Hi!
You can see this link to see how to remove crt and how to assemble it back carefully---
CRT Replacement
Thanks
Rylee
Posted on Jan 26, 2009
  • 130 Answers
THey are all a little different. Look it over closely for a way in. make sure you mark all the wires and be sure the new crt is compatible
    Genius:
  • 2,920 Answers
If you take the screen off the tv you can get to the tubes to remove them alot easier than doing it from the back. they are easy to remove from the front when you unbolt them and lift them out. you can work the rest of it from there
  • Ronnie Houston Jan 26, 2009
    you can still pull the crts from the front of the tv or the back its always been easier for me to do them from the front i have an hitachi i went through about 3 months ago and pulled the crts and put in new and had it up and working in less than 3 hours...your tv should be thesame as this one or maybe not. i dont know what else i can tell you
    Sergeant:
    Champion:
  • 435 Answers
Hi, Please specify the model number. I personally feel replacing tube would be expensive than getting a new TV set.
If you want to remove the tube, switch off the unit. Unplug and leave the unit for 5-10 mins (until the capacitors in the circuit get discharged.)
Remove all the connections leading to the tube. Do remember the connections which you need to connect back.
Remove the tube.
Insert the new tube and connect back everything.
Posted on Jan 25, 2009
  • 10,594 Answers
Let me know exact model number of Sony TV to provide you service manual.
Service manual has all technical details about CRT replacement.
  • Shahid Electronics
    Shahid Electronics Jan 25, 2009
    Below is an exploded view of CRT removal in KP-51HW40
    Shahid Electronics Jan 26, 2009
    Only thing to care is high voltage wire and you can pull it out from HV block easily and touch to nearby ground connection.
    there is PCB attached at base of CRT, pull it too, unhook Yoke connections from board, unscrew CRT and take it out.
    Pretty easy job.
    let me know what kind of more info you need in replacing tube in projection TV.
  • 10,515 Answers
Dude,
 the link wld be :)
 Awesome explanation with proper procedure.....
http://www.wikihow.com/Replace-a-Projector-Lamp
There is a video as well....
ba bye.
How to change picture tube(crt) in a sony kp57ws500
Changing picture tube is a professional job and involves many procedures that are beyond the DIY projects. How ever if you are really hot with electronic, you can attempt it at your own risk. Make sure set has been off for some time, disconnected, and HV discharged. You will have to open the hard board back then the plastic back cover on top. Remove the mirror, Be careful!! now you will see the three tubes choose the one you need to change. Its better to disconnect all and take the crt assembly out and then change the one thats bad. take care and do it if you are very sure of what you want. There are FAQs on www.fixurtvs.com. You can download service manual from tech support at fixya site.
Mar 24, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony kp51hw40 has green shadows and on edges in pictures and blue flickers on and off, tried all adjustments including screen, focus, and menu??? no luck
The CRTs in this model of TV had a problem with internal leakage. The blue was usually the first to show the symptom (flicker). Because all 3 CRTs are connected to the same high voltage source, when 1 acts up, the other 2 suffer as well. You need to replace the Blue CRT. However, this TV has some age on it... 1 tube will lead to 2 tubes, and 2 tubes to 3... They only last about 7 years. If you love the TV, replace all 3 (about $200 each). I recommend replacing the Red and Blue first, adjusting the geometry and convergence to the original Green. Then replace the Green, adjusting the geometry and convergence to the new Blue and Red.
Mar 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Can you buy a new or rebuilt Blue CRT for the KP51HW40?
There is no New Tubes Avaiable that I know of and Tucker gerogia was the Last Place I knew of that rebuilt them try Encompass Parts 1-800-638-3328 or PTS 1-800-844-7871
Dec 21, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a sony kp51hw40 bigscreen projection type tv and the picture turns red after a while, like all red, should i replace it or fix it?
TAKE THE FRONT OFF. THEN REMOVE COVER FOR CRT'S.BE CAREFUL YOU DON'T PULL WIRES OFF THE KEY BOARD.WITH TV ON ,TURN THE RED SCREEN CONTROL COUNTER CLOCK WISE A HAIR.I BELIVE IT THE CONTROL ON THE VERY LEFT.TURN SET OFF THAN ON, TO SEE IF THAT SOLVED YOUR PROBELM.IF IT NEED NOT THAN TURN THE RED SCREEN CONROL SOME MORE.
Mar 27, 2009 | Sony KP-57HW40 57" Rear Projection...
Front fabric panel
I have a Sony KP51HW40 TV that I am parting out. I could sell you the whole front panel. I also have the green and red picture tubes.
Feb 15, 2009 | Sony KP-51HW40 51" Rear Projection...
5 flashing light code
Disconnect RED Tube CRT board if set plays without shuting off RED tube is bad or video IC on CRT is bad.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony kp51hw40 projection tv screen turns blue
The blue CRT needs replacement. You can get a replacement CRT at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Sony KP-51HW40 51" Rear Projection...
Red and green colors not coming through in picture
Bad crt
Sony Picture tube recall
http://esupport.sony.com/perl/news-item.pl?news_id=24
Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Green Flash and Then Nothing After 20 Seconds
CRT nowadays have no replacements. Maybe you'll find 1 in the Philippines on surplus shops. Is a bad decision though
Apr 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
1,009 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
