Question about Kenmore 24032\24036 Top Load Washer
Clothes still have soap residue after 2nd rinse.
I have a Kenmore Elite Module 23032 washing machine. The washer has a two rinse cycle option – controlled by a selector switch on the control panel. The problem is that during the second (final) rinse a significant amount of soap film is still in the water. We have to rerun the clothes through the rinse cycle(s) two and three times before the water is reasonably clear. We use less than 1/3 rd of the recommended amount of soap.
I have observed the 1st rinse cycle which starts with the agitation cycle followed by the water draining out while the the tub is stopped. This is followed by a spin up to speed and then a fresh water spray of approximately 5 seconds after it is up on speed. Shouldn’t that fresh water spray be longer than 5 seconds and is that the cause of the problem?
  • 2 more comments
  • bobvos Jan 25, 2009
    Don't have a problem with the vingar cleaning but do you know what the intended duration the fresh water spray is supposed be?
  • bobvos Jan 26, 2009
    Did not change the soap (SA8). Have only used this soap. Just using smaller amounts. Never have a problem with cleanliness, just the rinse cycles.
    Problem has existed for 6 - 8 months.
    The water source is regular tap water. Have never installed a softener. Water out of all other taps is always clear. Even after repeated operator induced rinse cycles (3 - 5) the water will become clear.
  • 916 Answers
You may have a soap build up inside the unit. Run two loads with no clothes just hot water and a pint of bleach, let it cycle all the way through.
Your pump may be in the beginning of a leak and is just dripping but when the soap is leaving the unit, it bubbles making the leak apparent.
Does it seem like it is coming from the drain or under the unit?
Posted on Jan 26, 2009
  • Kenmore Master
  • 19,396 Answers
When machine does not rinse properly, and you get clothes wet and with soap then that means that tehre is a fault, either concerning water supply/inlet valve, or motor/motor control unit.
Check first if water is coming from water supply at the back with regular pressure.
If water supply is fine, and there is scarce water, then it is the inlet valve.
If water is flowing OK, then the machine is not spinning properly, in this case you check motor, motor coupler , and motor control unit.
See also:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
By entering model number here you can find parts and schematics for your appliance.
    Master:
  • 416 Answers
What about water quality. Is it well (artheisan) water or regular tap water. Do you use water softeners. Is it all the time problem or it started just recently.
Also you need to check water inlet valve if it is clean and water for pressure (it might be low).
Otherwise you have faulty selector switch on control panel.
Good Luck
Posted on Jan 25, 2009
  • Grigory Zyryanov Jan 26, 2009
    1. Are you sure it is a soap not grease. Try to run teh cysle with recommended amount. If it is for hard water the amount of softener
    with full load will eliminate the hardness for full loading. Maybe it can be simple solution.
    2. Check water hoses, air lock etc for cloggs. Soapy water might be just syphoning backwards after cycle complete.
    3. Did you try to change soap. Is it the same brand (not 2X concentrated).
    Good Luck
    Sergeant:
    Champion:
  • 435 Answers
How did the problem start? Did you change any settings or did you change the soap you are using ?
  • 10,515 Answers
Read the following article by an expert
Is cleaning your washing machine important? It certainly is! The inside of your washing machine is constantly being subjected to dirty water, mineral deposits, detergent deposits, and if you launder cloth diapers it is especially important to keep your machine clean and in tip-top condition. Much like dishwashers, sinks and bathtubs get dirty even though they are meant to clean things, your washing machine can become a mess in no time. Though, most dirt and soil is washed out with the water, dirt, soap residue and other unidentifiable grungy objects can be left behind and you actually have to get rid of this dirt yourself. Every time you wash your clothes, hard water and detergents cause build up to accumulate also, inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform and mineral build-up can be abrasive to your cloths and diapers you are washing, causing them to wear faster. Cleaning your washing machine eliminates these problems.
First, run a cycle of hot water along with two cups of vinegar or lemon juice to loosen up soap and grime. Remove the fabric softener receptacle and soak it in hot water and detergent. Clean the bleach dispenser with a spray cleaner and paper towels and Q-tips. Don't forget to clean the top rim of the wash bucket as it is up and under where it can't usually be seen easily and becomes dirty. Run the washer empty on a hot cycle one more time.
While this is going on you check all your hoses for leaks. Over time, the water hoses that came with your washing machine may leak or burst. It's a good preventive maintenance practice to check these hoses from time to time for any sign of wear or weakness. Most manufacturers recommend replacing the hoses every 5 years. Make sure your hoses are not a disaster waiting to occur!
Once you've soaked the fabric softener receptacle, replace it and polish up the outside of your washing machine with vinegar and a cloth towel. Your washing machine now looks better and will run better as well!...
ba bye.
  • taran_2005
    taran_2005 Jan 25, 2009
    Its absolutely correct...
     Ideally it must be between 3 to 5 seconds...
     Hope i have solved ur querry..Don not forget to mark this thread as fixya ...
    take care.
LG front load washer leaves clothes soapy. Yes cleaned trap and drum and use correct HE detergent. What else can it be?
front load machines can be soo frustrating-try using less detergent-you might try running a sanitizing cycle with a quarter cup of dry dish washer soap-sounds like your rinse cycle isn't working do you have an option for a 2nd rinse cycle-cheers Denny
Oct 26, 2013 | Washing Machines
When washing dark colors there is a soap residue left on clothes,i have tried using very small amounts of soap as well as different brands of soap
Try using white vinegar in place of liquid fabric softener. Half a cup at the rinse cycle in a full load will do it. Trust me, the smell of the vinegar will fade quickly as it works to break down the soap.
There are two other possibilities here:
You're overloading the washer with clothes - An overfull washer has the problem of not providing proper drainage before the spin cycle starts - Soap ends up getting embedded in clothes instead of being sucked out of the drain.
Or, You're using non-HE soap in an HE washer.
Hope that helps.
May 04, 2011 | Washing Machines
How to fix suds lock on Kenmore
The Sd code on most Kenmore Elite HE washers indicates a suds lock (usually caused by excessive suds do to overuse of detergent). Check for the presence of excessive suds in the washer. If you see a lot of foam, the code is likely caused by this problem. You will likely be able to drain the washer and spin out the clothes once the suds dissipate. Run an empty cycle with 1 cup of liquid chlorine bleach through the washer to help rinse out suds residue. If you see foam emerging during the empty cycle, you may need to repeat this process. You can also use Washer Magic or AFFRESH to help clean suds residue out of the washer. These products are available at your local Sears store or the grocery store. Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity. You may need as little as a tablespoon of detergent in a high efficiency washer due to the low water level. You may need even less for a while since the clothes will likely have detergent still dissolved in the fibers that will emerge during subsequent wash cycles.
There are many different models of Kenmore Elite HE washers. If you do not see any apparent problem with excessive suds or need more help, resubmit your question with additional details and the full model number of your Kenmore Elite HE washer.
Jan 11, 2011 | Kenmore Washing Machines
We have an Aquasmart top loader and our clothes, mainly dark items, are being covered by a scum after washing. We have put the machine through the clean cycle, but this has not made any difference.
I have found with my aquasmart that if you use the 'high efficiency' the water does not cover the clothes sufficiently which is why the soap residue (noticeable more on dark clothes) is visible. I don't use high efficiency. even on conventional sometimes I still have to check that the water level is high enough. Also **use only liquid, low sudsing detergent and do not put it on the clothes-use the dispenser only. As for my machine... Time for the repair man to check the sensing I think
WC Gold Coast
Aug 29, 2010 | Fisher and Paykel Washing Machines
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
The words Sud comes up in the rinse cycle. What does this mean?
You are putting too much soap before you begin the wash cycle...... When the word SUDS is displayed then on the rinse cycle there is too much soap and the suds are still on the clothes. Try cutting back on the soap, maybe cut back almost 1/2.
Jul 12, 2010 | Kenmore HE2 Plus Front Load Washer
How do you get rid of the musty smell in a front load washer.
38c7a1e.jpg MNTECH
Rank: Guru
Rating: 93%, 650 votes
Here is a response I recently gave to a person posting a similar problem. You do not state your model number, so: If you have a tub clean cycle, use that, if not, use the longest, hottest cycle with no clothes and a front load washer cleaner like Ahfresh, Washer Cleaner, SmellyWasher Cleaner, Tide front load washer cleaner, or Whilaway hot tub cleaner. Clean the tub gasket area by the door and remove the filter and clean it out also before you run the clean cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer. Now, after the washer is clean, USE ONLY ONE TO A MAXIMUM OF TWO TABLESPOONS OF HE LAUNDRY DETERGENT PER CYCLE !!!! (and no more than one teaspoon of fabric softener per cycle, if you use it)
You could check out http://www.smellywasher.com/ for one possiblity. The big thing is that these machines use very little water, and many of the newer soaps are 2x or 3x concentrated, so you have to use very little soap. (much much less than the soap manufacturers suggest) in order to rinse all the soap residue out of the clothes and prevent it from builing up in your washer and causing odors. (oh, by the way, that one cleaner I listed as Washer Cleaner is actually " Washer Magic ") 73b1c2a.jpg fb3071a.jpg
Aug 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Mar 12, 2009 | Kenmore 22422 Top Load Washer
Clean LED Light does not come on
no its usely the touch panel if everthing working dont bother with it about a 200 dollar part
Aug 26, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
118 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
