E7 error code
I have a Sharp AL-1451 copier and it is getting an e7 error code. Can this be fixed easily?
  • shapettit Jan 26, 2009
    When I press the print button it says 15. Not sure if that is a sub code or not. This does not sound like something easy to fix.
  • 46 Answers
This is a problem with your optical system.
what sub-code do you have?
Posted on Jan 26, 2009
  • peter kraft Jan 26, 2009
    according to the manual this is either a lamp or an inverter problem.
    as you can't check the lamp with an ohmmeter you have to have a sharp tech look at it.
My sharp al2021 showing f5-02 and e7-11 what can do to work
The service manual was not available for the AL-2021 but the error codes are the same for the AR-5316
F5-02 error cause and remedy
Sharp AR 5316 Service Manual Page 27
E7-11 error cause and remedy
Sharp AR 5316 Service Manual Page 26
Jan 07, 2015 | Office Equipment & Supplies
Showing code L 4 HOW DO i FIX IT
I don't know the answer but I am having the same problem with my Sharp AL-1451.. Can any one help?
Jul 11, 2012 | Sharp AL-1451 Laser Printer
Sharp AL-1000 error E7
E7 is CCD drive circuit trouble. Refer to the manual
obtainable from mauritron
Feb 21, 2011 | Sharp AL-1000 Copier
What does E7 Error code mean for SHarp AL-800 copier?
?7 03 Problem related to the brightness of the laser emission 04 Error in determining the level of white in the performance of hatching 05 Error in determining the level of black during hatching 12 Error output level in the performance of hatching 14 Failure ASIC (MCU PWB) 15 Trouble copying lamps
Sep 19, 2010 | Sharp AL 800 Copier
My sharp AL 1551 CS is getting a L1 error code before that it was getting a E7 code. The scanner will light up and shut right back down, then it shuts itself down again.
I have a tip posted here on Fixya that will help you diagnose and repair an L1 failure code on the Sharp AL series copier.
Here is the link:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
If this works for you then please return here and give me positive feedback.
Thanks for using Fixya today.
Jul 13, 2010 | Sharp AL-1551CS Copier
Error code E7-11
CCD drive circuit (CCD PWB, ASIC harness) trouble
Copy lamp lighting trouble (Copy lamp, inverter PWB)
OR the scanner shaft is dirty. Clean it and re-oil it with 3n1 oil.
Jul 17, 2009 | Sharp AL-1655CS Copier
Copier mod AL-1551CS gets a E7 error code and lock up. Whats up?
The E7 code is related to the laser and or the distinction between black and white being read/interpreted by the system. There should be a sub code which will point more directly to the problem. The laser could be bad or the glass and mirrors need cleaning. Remove the glass (with the copier unplugged) and clean including the white strip underneath, clean mirrors too.
Mar 20, 2009 | Sharp AL-1551CS Copier
Errore code E 7
Hi p_brooks
E7:
01:DUPLWX MEMORY PROBLEMS
02:LASER PROBLEMS
03:LASER PROBLEMS
10:CCD BLACK CORRECTION SHADING PROBLEMS
11:CCD WHITE CORRECTION SHADING PROBLEMS
12:CCD WHITE SHADING PROBLEM
16:LASER PROBLEMS
thanks
Hamedo
Nov 22, 2008 | Sharp AL-1451 Laser Printer
Sharp AL 1631
E7 has to do with the scanner. Make sure it isn't locked up or binding.
Oct 30, 2008 | Sharp AL 1631 Copier
261 people viewed this question
jasbo
jasbo
