Question about iHome iDM12 Rechargeable Portable Bluetooth Speaker System for iPod / iPad / iPhone
"how to open" broken idm12 - iHome iDM12 Rechargeable Portable Bluetooth Speaker System for iPod / iPad / iPhone
Hood Release is broken, can not open hood even when I pull on cable,how do I open the hood?
Since you do not say model, try this
http://www.bing.com/videos/search?q=open+hood+with+broken+release&qpvt=open+hood+with+broken+release&FORM=VDRE
open hood with broken release Bing Videos
Mar 26, 2015 | Cars & Trucks
Troubleshooting
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Gd bless you
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
How to take apart
The port was broken on mine also. I looked online and found no help so I decided tear it apart since it was broken anyway. There are 6 phillips head screws located under the speaker cover. The black mesh material is glued down so you have to pry it up and then peel. The backing tore on mine so it will be a challenge to actually remove it without damaging it. Once it is off, you can remove the 6 screws and it will open right up. The charger port is located inside a small black box that is held down by 2 screws. Once I got to the little charging port, I found that it had become separated from the circuit board and couldn't be put back on. Not unless you know how to solder or do circuitry. I figure it isn't repairable.
Dec 27, 2012 | iHome iDM12 Rechargeable Portable...
How to take apart idm12 ihome speaker
Pry the front grill cover from the edges. There will be 6 screws to remove before it will come apart.
Nov 24, 2012 | Audio Players & Recorders
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
How do i open a stuck or broken hood latch
easiesyt way to open broken or stuck latch is to go to a fire dept
they have a special tool made for opening broken and stuck hood latches
Dec 14, 2010 | 1993 Eagle Summit
How do I open hood on a 2005 montana when hood cabnle is broken
pull the broken cable down from under the dash, cut back the cable sheath to expose the wire cable inside, then use a good pair of vise grips to pull the stub of the broken steel cable to open the hood.
Oct 01, 2009 | 2005 Pontiac Montana
Door only opens about 3 inches
You have a broken spring on the door. Stop tyring to open door with opener immediately or you will have a broken opener and a broken spring
Oct 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Jan 29, 2008 | Washing Machines
iHome iDM12 Rechargeable Portable Bluetooth Speaker System for iPod / iPad / iPhone Logo
110 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
