Question about Pitco Frialator SG14 Deep Fryer
Lighting the fryer
How do I light the pitco gas fryer
    Problem Solver:
  • 11 Answers
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Posted on Feb 01, 2009
My pitco fryer SFSG18 will not light it has spark but does not seem to be getting gas when trying to light
Have you tried inspecting/replacing the thermocouple? This is the thing you heat when initially lighting the pilot.
You may also have a stuck pressure valve, but that is unusual.
Apr 02, 2016 | Pitco Frialator SG18S Deep Fryer
.poilit light on but not burnner on even i turn
Check if the gas valve knob is set at "ON" position after lighting the pilot. Check also it the thermopile is receiving enough heat from pilot flame and try also to tighten all wiring connections on gas valve, thermostat and hi limit. If these do not seem to correct the problem, you have to replace the thermopile.
Feb 28, 2011 | Pitco Frialator SG14 Deep Fryer
Pilot light works but gas wont turn on.with temp guage turned up?
Check if you have turned the gas valve knob to "on" position after lighting up the pilot. If so check for the continuity of the thermostat terminals using an ohm meter. If the thermostat is good, try replacing the thermopile, if it does not correct the problem, try replacing the gas valve. Make sure that the unit receives sufficient gas pressure and volume before doing part replacements.
Feb 05, 2011 | Pitco Frialator SG14 Deep Fryer
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
Jan 27, 2011 | Pitco Frialator 35CS Deep Fryer
Flame rollout. Lit pilot turned thermostat on burners lit. Turned thermostat off for a few seconds and turned back on can hear gas but not lighting. If left alone it blows the door open and makes noise. I...
Hello There:- You have two problems here. 1. the gas rolls out caused by the blocked gas flue or your deep fryer chemney needs to be check out. 2. the unit door blows open caused by what we call this delay lighting, it is quite dangerous, you should check out the whole unit , the pilot light may be too small and not lighting up the main gas as it should and when it does it is too late too much gas in the chamber and blows out through the front door. Hope this help.
Sep 19, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
Lazy lighting
Check incoming gas pressure, you may also need to clean out gas orafices. make sure you have the right orafices installed(nat or LP)
Sep 10, 2009 | Pitco Frialator 35CS Deep Fryer
What is the "kettle"?
The kettle is mentioned as the fry pot just different slang.
Nov 06, 2008 | Pitco Frialator SG14 Deep Fryer
Pitco Fryer
Sounds like the burners are dirty remove burners and run under cold water and replace propane gas burns dirty and might have blocked up burners creating a pop at the burners this will then blow out pilot light if this does not work give me a shout
Jul 27, 2007 | Pitco Frialator SG18S Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
177 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
