Question about Spherex Xbox 5.1 Surround Sound System Computer Speakers
Keeps powering down right after its turned on
Why does my xbox keeps turning off
...check if your power cords are plugged in right and you have a surge protector outlet.
Disable any cooling devices as they can steal current form the box and make it shut down.
Aug 24, 2014 | Microsoft Xbox 360 Slim Black Console
There was a power outage, and the red light on the printer keeps flashing but it won't print
Click on start and type services.msc and hit enter. Then scroll down till you see print spooler, right click it and say stop, count to 5 and right click it again and say run.
If this doesn't fix it try turning the power off on the printer and unplugging it and waiting 30 seconds then reverse the steps, plug back in and turn it back on.
Apr 04, 2014 | Dell 1130 Laser Printer
WHY TV KEEPS SHUTTING DOWN AFTER ABOUT TWO SECONDS AFTER YOU TURN POWER ON WITH NOTHING ON SCREEN
If the light just goes off then look at the ballast . If the whole set goes off then look at the power supply board.
Jan 24, 2014 | Philips 50P8341 50" Rear Projection...
Toshiba laptop satellite L645D-4040 keeps shutting down
does it shut down and then just start right back up? If it does then press and hold the power button and make sure it shuts down all the way. Then take the battery out and press and hold the power button after the battery is out for about 5 seconds. Then let it sit like 10 - 15 seconds. After that put your battery back in and turn it back on and see if this solved your problem. I think its in a loop to make it keep restarting. Let me know if this helped. Thanks, Herb Stacey
Oct 04, 2013 | Computers & Internet
When i go to turn on my LG 50PG20D-AA plasma tv, the green power light turns on for a couple seconds, the LCD turns on, then flicks off again, it keeps repeating the process until you disconnect the power...
everyone is wrong here.
Disconnect the power from the mainboard the board down on the right hand side.
now short out the auto_gen with a peice of wire while tv unplugged.
after this process plug it in.
You should see a test pattern this will rule out Y-sus and Z-sus problems.
Problem will be main board.
Dec 28, 2012 | Televison & Video
My computer keeps switching itself off and won't swtich back on again? What can be the problem?
Hello
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
Oct 30, 2012 | LG Computers & Internet
Pentair intellitouch electronic breaker keeps tripping
check pump see if popping or heater unplug auxs until it doesn't pop if keeps maybe bad transformer
May 04, 2012 | Pentair Intellitouch Power Center Includes...
Shuts down
This is a typical symptom of a failing power supply. Replace your power supply and see if the problem still persists.
Please notify me should you need any further assistance.
Best wishes,
Graemevm
Jan 06, 2012 | Intel DP55KG Motherboard
My garmin nuvi 1300 keeps turning off after only a few seconds. Its fully charged.
try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update
Dec 20, 2009 | Garmin nuvi 1300 Car GPS Receiver
Can't power down my YP-T9J
mine had a horrible glitch with the computer and now its stuck on the connected/charging screen and wont power down and wont change screens!!!!! please someone help me
Apr 21, 2008 | Samsung Yepp YP-T9 Digital Media Player
Spherex Xbox 5.1 Surround Sound System Computer Speakers Logo
26 people viewed this question
Top Spherex Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Spherex Audio Player and Recorder Expert? Answer questions, earn points and help others
