Question about Simplex 2098-9575 477-674 Ionization Detector
Want new detector model # 2098-9575 - Simplex 2098-9575 477-674 Ionization Detector
Can you show me where to get the user manual for a cobra superwide laser detector with model number r-213
Unfortunately, Cobra does not provide secondary or tertiary manuals on their website for this old model of Laser Detector.
Your best bet would be to either purchase a new Laser/Radar detector from Cobra and get the manual from that.
Hope this helps.
Thanks!
Jun 03, 2011 | R-213 Radar Detector
My nighthawk Kidde carbon monoxide detector keeps beeping every 25-30 seconds. Do I need to buy a new one?
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
Jun 27, 2010 | Kidde Nighthawk Combo Gas/co Detector
I have 7 year old smoke and carbon monoxide alarm...I have put a new replacement battery and detector is chirping every 15 seconds or so
Check the expiry date on this unit. The manufacturer recommends replacement usually after 5 to 7 years depending on the model.
You bought a Combo Gas/CO Detector for protection against the hazards of Gas and Carbon Monoxide poisoning. A new unit will give you the peace of mind you are looking for.
Visit my website for more information and view most Brands and Models of Carbon Monoxide and Combo Gas/CO Detectors.
Dec 20, 2009 | Kidde Nighthawk Combo Gas/co Detector
How can i repair a scratchy sounding radar detector speaker for a cobra xrs 797 model?
replace the speaker cobra sells them for a few dollars
773-889-3087 or cobra.com also if you want a new detector you can send your old one in and they will upgrade to the next higher model at a good discount ( a lot cheaper than buying through the stores .
the speakers are easy to install just plug in no soldering required .
Dec 14, 2009 | XRS 797 Radar Detector
KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Jun 03, 2009 | Kidde Nighthawk Combo Gas/co Detector
Need new spearker
This model has been out of production for quite some time. You could try contacting Uniden to see if, by chance, they still have some replacement speakers for this older RD model. In any event, you would be well served to purchase a modern radar detector which provides far better performance. Personally, I recommend products produced by the following manufacturers:
Bel
Escort
Whistler (their higher end products -- XTR-690 model or higher. Their Pro78 or newer Pro78SE is one of my favorites.)
Valentine
Apr 19, 2009 | LRD777 Radar Detector
NEED INSTRUCTION/OWNER MANUAL
Uniden has been out of the radar detector business for some time now. I would strongly suggest getting a different radar detector instead of using this older model since newer radar detector models generally have far better performance -- especially for detecting Ka band radar.
Anyway, Uniden's web site does not list an instruction manual for this particular radar detector model. Yet, take a look at the instruction manual for the most similarly numbered product model shown in the following link:
Uniden Owners Manuals -- Radar Detectors
One of the instruction manuals in the above link should be similar enough to your radar detector so that you can figure out everything regarding your specific Uniden RD model.
Apr 13, 2009 | Uniden Vehicle Parts & Accessories
Got this from a friend but never used one before so I don't know to much about this radar detecter could you give me some advice?
The best place online to learn about radar detectors and how to use them is radardetector.net. I would highly recommend a new radar detector model compared to any old Uniden radar detector. Uniden has been out of the radar detector business for some time now.
Apr 07, 2009 | Uniden Vehicle Parts & Accessories
Escort doesn't work
There is no place where you can send it in for any type of service. Not only that, your Solo's performance is horribly outdated compared to any current Bel or Escort radar detector model. Even Whistler offers high end models which significantly outperform your old Solo. It is time to upgrade, plain and simple.
Dec 18, 2008 | Solo S2 Radar Detector
Smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
Simplex 2098-9575 477-674 Ionization Detector Logo
21 people viewed this question
Top Simplex Home Security Experts
Lawrence Oravetz
Are you a Simplex Home Security Expert? Answer questions, earn points and help others
