Cannot find conditional access module for 40" polaroid t.v.
Forgot password to Polaroid model a10 tablet
Hold and press the reset button 40 seconds and then re-press. see if that lets you in to access your tablet so you can reset your password.
Jun 26, 2017 | Polaroid Tablets & eReaders
40 inch polaroid lcd tv
This is a common problem with Polaroid sets. I would check the power supply/inverter board for any capacitors with bulging tops. The typical ones that cause this problem are 10uf 450V caps.
May 07, 2013 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid 40 in lcd tv flickering when warmed up
If the set has several thousands of hours, the CCFL tubes are about due for replacement.
Before you commit to that expense though, check the condition of the capacitors on the inverter board(s). If they are showing any signs of stress failure, replace them and try that for awhile. If they begin to fail within a year again, the tubes should be replaced with capacitors. You want to use high Ripple Current types, not general purpose types.
Sep 30, 2011 | Polaroid TLA-04011C 40 in. LCD TV
I have a 37 inches polaroid tv and, it was working fine at night, in the morning when I turn it on, a a black spot show on the right side of the screen
Depending which model, this tv may have an inverter master and slave module set. I find best to replace as a pair. These modules feed the flourescent lamps that backlight you lcd screen. more than likely the one failing is on the same side as the spot you are seeing. I always first look at the power supply panel, to be certain that capacitors on this board have not failed or leaked out.
Parts look here http://www.shopjimmy.com/tvs
Jul 09, 2011 | Polaroid TLA-04011C 40 in. LCD TV
40''polaroid lcd(4011TLXB) has power to it but no pcture or sound? whats difference from power supply board and main control board
Power supply module is to supply voltages to the main control board (the board where the TV cable and video cables are connected to), backlight inverter board. You can buy the whole control box which has both board assembly (power supply and the main control board): http://www.shopjimmy.com/catalogsearch/result/index/?q=Polaroid+4011-TLXB+&limit=25
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 25, 2010 | Polaroid 4011-TLXB LCD TV
My 2006 harley sportster started running rough & the engine check light came onthen the light went out it ran fine for a minutethen rough again it would only do 30/40 mph getting me home??
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Harley Davidson Sportster error codes and how to access them
May 21, 2010 | 2006 Harley Davidson XL 883L Sportster
Problem on polaroid 04011c not shoving menu display or volume or eny command
Does your set respond to the controls on the set itself?
If you, are you able to access the setup menu to perform a factory reset?
If so, press menu, navigate over to setup, then choose reset defaults, to see if that improves your situation.
I hope that helps.
_________________________________________
Polaroid TLA-04011C Manual Download
Polaroid TLA-04011C Service Manual Download
Apr 26, 2010 | Polaroid TLA-04011C 40 in. LCD TV
TV won't turn on
I have fixed many polaroids, the problems is most of the parts are contained in one self contained control box. it sounds like your power board is not funtioning. contact polaroid and let them know about your problem and see if you can get a new control panel. the contol panel only has one connection and 3 screws to replace. hope this helps.
Apr 08, 2009 | Polaroid FLM-4034B 40 in. LCD HDTV
No Sound ... (main input module) ?
the module itself is 56.00 dollars then the labor to install, its hard to find the seperate components the factory has set things so that you have to buy the whole control module to replace one part or board. try and find that component on e bay or used some where thats your best bet to fix it.
Dec 17, 2007 | Polaroid FLM-3225 32 in. LCD Television
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
