Question about Minn Kota Boating
Minn kota edge 70 problems - Minn Kota Boating
tbirdfan1
  • 3051 Answers
SOURCE: Where can I get installation manuel for Minn Kota bow mount maxx?
Hi there
if you go to the web site of the manufacture they havre a printable version of the manual there is even a phone number to call for help please try this ok and let me know how this works for you
best regards mike
Posted on Mar 06, 2009
  • 10 Answers
SOURCE: proper batterie hook up on minn kota 70 thursh
Raventrans click this link to take you to a website which will you can click on schematics. I suggest adding a 50 amp fuse for your 70 lb thrust unit. scroll to the end of the schematic to find the battery hookup for a 24 volt hookup.
http://www.mikesreelrepair.com/./index.php
Posted on May 08, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Posted on Jul 13, 2009
SOURCE: what size battery does a minn kota 565 5 speed
12 Volt
Posted on Jul 17, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    I have lost speeds 1 thru 4 on a minn kota edge 70. 5 still works fine where should i start troubleshooting
    Hello Richard,
    It has been some time since I have been around trolling motors but it sounds if the variable speed sensor or switch is either corroded or burnt out. Since you had the speeds and they are slowly disappearing it sounds if the switch is failing. If you are somewhat mechanical and know how to test using a volt ohmn meter you can check the switch this way to see if it is the switch. If the switch tests fine then your circuit board in the motor head or foot pedal has gone bad.
    Hope this helps some
    Oct 29, 2014 | Minn Kota Edge 70 45" - 1355970
    Minn kota
    I have a terrova with i pilot same thing happened found out it was the remote, if thats not it then you will more than likely have to send it in for repair.
    May 13, 2014 | Minn Kota Riptide Sp Saltwater 70 Bow...
    My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
    Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
    Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Broken plastic on minn kota steering cable
    Hi!
    Here's a schematic:
    Edge 40
    My guess is you need key# 80 (part# 2232360 cable drum pulley)
    Good luck in your repair!
    Mike
    Sep 19, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    Year made MKAD2674059 minn kota
    According to: http://www.northlandmarine.com/MinnKotaMotorControlBoardAssm.htm
    *Note: Newer model trolling motors have serial numbers beginning with the two-letter prefix MK (Minn Kota), followed by a two-letter year code. MKAB .......... 2001
    MKAC .......... 2002
    MKAD .......... 2003
    MKAE .......... 2004
    MKAF .......... 2005 MKAG .......... 2006
    MKAH .......... 2007
    MKAI ............ 2008
    MKAJ ........... 2009
    MKBA .......... 2010 A serial number with the designation MKAB denotes a
    2001-motor and MKBA would be a 2010-year model
    Jun 13, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    I cant adjust foot tension on minn kota edge
    Hi!
    Flip the foot pedal over and tighten the set screw where the cable enters, this should help out.
    Here's a schematic:
    Edga 40
    Best of luck!
    Mike
    Jun 06, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    Proper batterie hook up on minn kota 70 thursh
    Oct 15, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn Kota electric motor MKJI1033962
    Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
    800-227-6433 they will help you with any technical questions.
    Parts can be purchased from this dealer...There are schematics on the site for review....
    http://www.northlandmarine.com/MinnKotaQuickRef.htm
    =100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
    Aug 10, 2008 | Minn Kota 40 Edge Bow Mount With Hand...
    Boating Logo
    91 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
