Question about Cuisinart BFP-703 SmartPower Duet Food Processor
Food processor Cuisinart BFP-730 The steal chopping blade is stuck in the bowl and attached to the gear box. Will not move up or down. how do I get it out?
  • Anonymous Jan 06, 2008
  • Anonymous Mar 01, 2008
    Corollary problem: stem is stuck to the gear box collar. I can use the slicer/shredder and remove the disk but I cannot use the food processor chopping blade because I cannot remove the stem. "Goo Gone" did not loosen the stem, nor did running the machine with just the stem but no disk.
  • 8,596 Answers
If the blade is actually fused, I would seek professional help to avoid slicing your fingers off. You can test to see if it is fused by removing the lid of work bowl, twisitng work bowl to the left, and removing the work bowl - if work bowl will not come off (difficult even under normal circumstances), then find out from Cuisinart if you are still under warranty.
Posted on Dec 10, 2008
2 Suggested Answers
SOURCE:
SOURCE: food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Posted on Oct 08, 2008
Why wont my chopper blade come off in the unlocked position?
Help! My Cuisinart is Stuck! - Chowhound
www.chowhound.com/post/cuisinart-stuck-353459
Dec 21, 2006 - Read the Help! My Cuisinart is Stuck! discussion from the Chowhound food community. ... The lid seems stuck and won't come off. I've tried pressing down,... Make sure all the buttons are in the neutral position. Reply ... In case of clarification- Turn the lid back on before unlocking, then twist off. Reply.
How to remove a stuck Kitchenaid Food Processor Blade (blade in ...
https://answers.yahoo.com/question/index?qid...
Aug 25, 2009 - Now the blade in the smaller bowl (4 cup) does not come off the bowl.... UNless i take out the 4 cup bowl blade, it doesnt allow me to remove the bowl ... I've used the screwdriver method for years in my shop with nearly 100% ...
Jan 12, 2016 | Food Processors
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Put in nuts and turned to mush
It is extremely difficult to chop walnuts in a food processor, because they turn to powder within a few seconds. I have chopped them using both a Cuisinart food processor and a Moulinex La Machine. The difficulty arises because even after you have released the on or chop button, the blade continues to spin for a second or two. The Cuisinart DLC-8S is not particularly well-suited for chopping nuts, because the blade is not reversible - there are many Cuisinarts that do have reversible blades - a particularly good one is the Cuisinart DLC-2A, which has both a reversible blade and a Chop function (retails for about $29.99 to 39.99 nowadays).
The only way to have any success whatsoever with the DLC-8S is to press the pulse button and release immediately - only use a small amount of walntus - and then dump the bowl and add a few more at a time.
Apr 04, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
My mini cuisinart stopped working
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals (p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Instructions for the food processor of my Cuisinart Duet
Here is the link to the user manual with visuals 9p.6 is most helpful):
-Tha Mp3 Doctor
Grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
Feb 01, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Food processor
Oct 07, 2008 | Cuisinart DLC-5 Food Processor
How do i remove the blade of of the bowl?
Remove bowl lid first
Then twist bowl to left (as you face front of machine)
Lift bowl up - blades will come with it
Feb 11, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
Blender Dead as a Doornail
open unit wil find thermal fuse replace.alternative the lid that covers bowl normally turns cliickinto position .this activates aswitch check if properly locked in
Mar 21, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Cuisinart BFP-703 SmartPower Duet Food Processor Logo
888 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Bruce Showalter
Donni Steen
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
