Question about MSI 661FM3-V SIS661FX LGA775 2DDR 400 2 PCI S-RAID ATX (04661FM3V) Motherboard
661fm3-v flashing power
  • MSI Master
  • 3,606 Answers
Hello here is the msi homepage:
http://www.msi.com/product/mb/661FM3-V.html#/?div=Manual
What`s the problem ??
Posted on Jan 19, 2013
Msi n1996 661fm3 graphics card
Hi, you can download the driver here:
http://www.msi.com/product/mb/661FM3-V--PCB-2-0-.html#/?div=Driver&os=XP%2032
Please select your operating system.
Click on the graphic driver and download.
Unzip the file before installation.
You maybe have to install the system driver first.
Sep 05, 2011 | MSI PM8M-V Motherboard
I need the install cd or where to find the drivers for MS-7103 v.1, 661fm3. Thanks.
Hi, you can download the drivers here at MSI:
http://www.msi.com/product/mb/661FM3-V.html#/?div=Driver&os=Vista%2032
But there is to different versions of your product.
Here is the other one:
http://www.msi.com/product/mb/661FM3-V--PCB-2-0-.html#/?div=Driver&os=Vista%2032
Remember to select your operating system.
Or you can download and install the live update function from here:
http://www.msi.com/service/download/
This will download your drivers needed.
Hope this will help you.
Apr 18, 2011 | MSI 661FM3-V Motherboard
Want sound
Download here at Msi:
http://www.msi.com/product/mb/661FM3-V.html#/?div=Driver&os=XP%2032
Unzip the file before you install.
Good luck
Feb 06, 2011 | MSI 661FM3-V Motherboard
MSI 661FM3-V Motherboard boots for 15sec then turns off
make sure that chip on the mother board is grounded with that alumnun housing if that chip get hot its shots down its a square chip thats black see even if it on it make sure that it is on it tight so no overheating will happen.
Feb 05, 2011 | MSI 661FM3-V Motherboard
Ethernet controller driver msi 661fm3-v windows 7
Download here at msi:
The ethernet driver is in System & Chipset Drivers
Click on zip file for download
Unzip before you install
You need reboot after this
Good luck
Oct 01, 2010 | MSI 661FM3-V Motherboard
No power
change the transistor power and capasitor ( near the socket power ) if doesnt work resoldering point prosessor socket ( bottom side of the mainboard )
Apr 24, 2010 | MSI 661FM3-V Motherboard
How motherboared read sata hard?
There are 2 SATA connectionsfor your motherboard near the bottom right-hand corner of the board - the little bright orange rectangular slots. Plug the SATA cable in there, and make sure you also connect eh drives to the power supply.
Mar 09, 2010 | MSI 661FM3-V Motherboard
Cant detect MSI 661FM3-V LAN driver for win7
eventually through continued research, i found out that this is a common issue with several mobo ang win7... SIS driver for LAN was the answer. i just downloaded the driver then install manually. although there is still no driver support intended for win7 as of the moment, vista driver does the trick...
Feb 01, 2010 | MSI 661FM3-V Motherboard
I need to connect h.d sata with motherboard msi 661fm3-v
I assume you mean how.
Reakky sata is easy, Just clip on to the right port and plug power. Your system shoud be able to autodetect it. Just make sure that you go into th bios and make sure that sata is enabled.
Mar 17, 2009 | MSI 661FM3-V Motherboard
Driver
MSI 661FM3 V
Link Download :
SiS® 650/650GL/651/661FX/740/761GX/67x VGA Drivers
XP :
Vista :
SiS® 650/650GL/651/661FX/740/761GX/67x System Drivers
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
XP64bit :
SiS IDE Drivers
XP :
MSI 661FM3 V (PCB V2.0)
SiS SATA Driver (For floppy driver)
XP/vista :
XP :
Vista :
XP :
Vista :
XP :
XP64bit :
SiS IDE Drivers
XP :
Sep 17, 2008 | MSI 661FM3-V Motherboard
MSI 661FM3-V SIS661FX LGA775 2DDR 400 2 PCI S-RAID ATX (04661FM3V) Motherboard Logo
67 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
