Question about Samsung Q1 Ultra Tablet PC
I am installing a new hard drive on NP-Q1/600 and I am receiving an Error Code 0200 Failure Fix Disk. I can see the disk in the bios.
I purchased a new Toshiba 1.8" PATA ZIF 60GB Mk6028GAL Hard Disk Drive for my unit. When I powered up the system, I get an Error 0200. I can see the drive in the bios but when I attempt to install windows xp I can only see a small partition but when I attempt to Windows 7, I can only see the entire drive but windows can't install on this disk...Can anyone help me. I've been working on this issue for over 5 hours...thanks
2 Suggested Answers
gymowner
  • 679 Answers
SOURCE: Hard Drive
Format the drive and delete the partition first
Posted on May 23, 2010
My toshiba r15-s822 says it has no drive and gives a (Ide#0 ERROR) i had a virus and i formated the drive a while back and i got a new windows xp install but i cant seem to load it cause it wont show the...
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
Aug 23, 2011 | Toshiba Satellite R15-S822 Tablet PC
Toshiba portege 3500 tablet saya tidak bisa booting lewat external cd room .. yang ada di layar monitor terbaca : intel(R) boot agent version 4.1.06 copy right (C) 1997-2002, intel...
It means that the BIOS cannot find a disk to boot.
Make sure you selected the hard drive in the boot settings of your BIOS
Remove all external DVD drives or floppy drives or ethernet cables
If you get an error message, you should start troubleshooting your hard drive.
Feb 27, 2011 | Toshiba Portege 3500 Tablet PC
Unable to install OS on Hard drive. Error PXE-E61: Media test failure, check cable. PXE-MOF: Exiting PXE ROM. Invalid partition table
When your computer failed to boot from the disk-drive, it tried to connect to a network-accessible "boot-server" via the Ethernet adapter.
However, if there's no cable connected to the computer's Ethernet port, you will get the "check the cable" error-message.
So, your real problem is "invalid partition table", which means that the very first record on the disk-drive is either missing or corrupt.
That first record contains the "partition table", which lists the size of the hard-drive, and the size of each partition (usually only one) on the hard-drive.
So, you'll need to buy an adapter that has a USB-plug on one end, and a connector for your "SATA" or "IDE" hard-drive at the other end.
Remove the hard-drive from your computer, attach it to the connector, and plug-in the USB connector to a USB port on another computer, and then use software to delete and then reconstruct the partition table.
Or, the hard-drive is failing, and must be replaced (maybe under warranty???).
Oct 22, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
My hard drive also failed. i cant install or repair the os on it.
the best way you'll need a USB CD ROM Drive so you can boot from USB with the windows CD in the drive and install from there.
Aug 10, 2009 | Compaq tc4200 Tablet PC
Operating system not found
That error message just indicates that the syswtem tried to do a network boot and couldn't since it did not detect an Ethernet cable connected to the port. Apparently your hard disk has died and needs to be replaced or your BIOS settings have changed and your hard disk is no longer in the boot order. Check your BIOS settings to confirm.
Jun 07, 2009 | Fujitsu LifeBook T3010D Tablet PC
Boot up problem
this is a easy fix all you need is a windows xp installation disk.what you do is put the disk in and boot off of the cd option.if you need help with the xp cd installation i can write up a guide for you.also is the first harddrive new or came with the comp.if it is a new harddrive it might not have a operating system on it.email me if you have anymore qeustions or you want the guide.i can even make a video for you but it probably won't be good quality.
Apr 23, 2009 | Toshiba Portege 3500 Tablet PC
System getting disk boot failure r disk error report
It could be a problem with your hard drive. It's starting to fail, may be some day you cant boot anymore. Try replacing it!
Jan 22, 2009 | Tablets & eReaders
I have a lifebook t2440 i tired to put windows xp home editon it went to setup and started sherching for a pervious operating system and it came back and said no hard disk drive found.what versions of...
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jan 16, 2009 | Fujitsu LifeBook T4220 Tablet PC
Boot
sounds like hard disk faliure, suggest getting a new hard disk or perhaps attempt a system reinstall. Its not the fan but the hard disk.
Geoff
Aug 28, 2008 | Tablets & eReaders
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
Samsung Q1 Ultra Tablet PC Logo
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
