Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch washer over fills with water
Washer fills with water and starts washing as usual ... but the water continues to fill. I turned the water faucet off when the water level in the machine was almost to the top of the glass window. Once I turned the water off, it washed, drained and spun ... when starting the rinse, same thing with overfilling happened again.
  • Bosch Master
  • 17,129 Answers
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 19, 2013
  • 116 Answers
SOURCE: How to increase water level in my frontload
The water level is not user adjustable but if there is a problem then the analog pressure switch should be changed.
Posted on Mar 11, 2007
  • 8 Answers
SOURCE: Bosch Washer
Yes, check the brushes. Our 7-yr. old WFK-2401 just stopped spinning and a brush change did the trick. Repair people wanted $350 for a whole new motor, but it was only the brushes. Replacing them is not very difficult if you are somewhat handy with a 1/2in. wrench and have some common sense about mechanics and electrics. Just look carefully as you loosen motor - disconnect its wires first, and think, and study, and try to understand what you're doing. I took lots of photos just in case. In the end it was easy; make sure to get belt off motor and motor will be out in no time; just two bolts to undo. Also, make sure you put brushes in properly - their tips are slanted and need to go in the right way and make full contact with commutator inside. Again, common sense. Bosch sells brushes, also RepairClinic.com, for slightly more but real Bosch parts. I paid the latter $45 with shipping - Bosch part No. 154740. Another option is to take motor out and find local motor repair shop and have them do it. Bosch won't help you. Power to the people - and the motor!
Posted on Sep 05, 2007
barkencoa
  • 3463 Answers
SOURCE: front loading washer does not advance past the rince cycle
Check and clean filter, it is usually located behind a plastic panel at the bottom front of the washer, remove cover and unscrew the filter cover anti clockwise, pull out and clean, replace and test, if it still does not drain, then possibly pump blocked or faulty.
Plz rate my solution.
Thanks.
Posted on Jan 07, 2009
SOURCE: Bosch Nexxt 800 washer won't drain clothes fully
There is not a Spin Only Cycle BUT there is a REFRESH cycle that will take about 10 minutes.
Sometimes when the load is unbalanced and the machine can not balance the load by itself, the clothes will remain soaked. To avoid this, make sure you always have a balance of small and large things and when loading your machine, do not shove the items in so they ball up.
Posted on Jan 09, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
Bosch frontloader will not spin or agitate
You can check the following things in your washer:
1. Is the washer door or lid closed?
a. If yes, does it filled with water?
b. if no: Please contact the manufacturer to replace the door latch.
And if it is not filling properly then there is a water supply issues like: hot or cold faucets closed or not open completely, hot and cold hoses reversed, kinked or pinched fill hoses, plugged inlet screens or insufficient water pressure
Jul 22, 2016 | Bosch Washing Machines
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
Machine keeps filling up, replace pressure switch, still nohting, keeps filling up?
Hello dwl770 - If your washer won't stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
Sep 30, 2012 | Frigidaire FEX831CS Top Load Stacked...
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off an on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
The hot water will not stop running. The cold water works fine. The machine is off but the hot water continues to run into the machine until I turn the faucet to the off postion..
The water fill valve in the machine has got stuck open or has dirt in it....
To fix this you will need to replace the fill valve or have it replaced...
The fill valve is usually part of the piece that the hose hooks to on the back of the washer...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 07, 2011 | Kenmore 24032\24036 Top Load Washer
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
Won't wash
You need to check and replace the brushes in the motor if they are less than 3 or 4mm long.
Access is usually from underneath the washer, this means laying it on its side.
Mar 01, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
My GE washer wont stop filling in any cycle. Even if you pull out the plug. Leaks everywhere. I blew into water level switch hose and it clicks. Model number WBXR1060T. Thank you
If water continues to fill and you have unplugged the washer from the wall then your fill valve is stuck open and needs to be replaced. Turning off the water at the wall faucet should stop the water. The fill valve is what the hoses are attached to at the washer.
Feb 02, 2010 | Washing Machines
My Kenmore top loading washing machine is leaking from the bottom. The water is dripping from the bottom of the front panel. What needs to be fixed and how do I do it?
This symptom usually indicates that you have a failed inlet solenoid water valve assembly. Completely unplug the washer from the electrical supply and see if the water stops filling. If it does, then you likely have a control board failure. This is rare but possible. If the water continues to fill with the washer unplugged from electricity, I recommend shutting off the hot and cold water supply faucets behind the washer. It is likely that the water will stop filling the washer. This would indicate that you have a failed water valve assembly.
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore series 70 top load washer - cold water fill very slowly.
The screens in the line are clogged. There is usually a screen in the washer hose at the point where it is connected to the faucet as well as one by the water inlet valve. NEVER REMOVE THE SCREEN BY THE WATER VALVE. As for the one in the cold water fill hose, that can be cleaned or replaced.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
129 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
