Question about Emerson LC320EM9 32 in. LCD HDTV
My 32 inch Emerson tv won't stop changing channels. what can i do to fix this?
It is changing channels on it's own and the only way to make it stop is to hold both channel buttons at the same time and that only works for a few minutes. what can i do to fix this issue?
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
dsacco86
  • 1077 Answers
SOURCE: Emerson 32 inch LCD TV will not come on.
I'm sure you already checked the outlet and the surge protector bar. It's lame how the warranty only last a year on this TV.
If your lucky, it will be just the fuse that need to be replaced. It will look like a little glass tube with metal caps on the ends. Radio Shack or an Electronic supply store will have the fuse. Just show them the fuse and they should match up the type and size. It needs to be 4amps and 125volts fuse.
If this doesn't work, you'll need to replace is the power supply board. The board# is BA71F0F01042. Your power supply board should have the same number on the lower right side of this board.
The board is hard to find right now. Only three places I know of to find it.
Ebay,
Discount-Merchant.com,
and Shopjimmy.com
Sadly, nobody has them in stock.
I wish I had a extra board to sell you, because I know how to repair the power supply. I have the schematics diagrams and part# for the pieces on the board.
If you ever come across a replacement board, let me know. I would like to buy your old board. Here's my e-mail, www.dsacco86@hotmail.com
Posted on Apr 14, 2009
dsacco86
  • 1077 Answers
SOURCE: My 32 inch emerson powers up and cuts off after a few seconds.
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TVs made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TV is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again. d66cb18.jpg
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com:
http://www.tvtechcenter.com/xcart/search.php?mode=search&page=1 It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15.
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
Posted on Sep 10, 2009
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
  • 19 Answers
SOURCE: my Emerson HDTV 32 inch sound stopped working all
everything with sound picture av component has to do with the main board of the tv not the power supply the only thing you can do its replace the main board not the power supply board or anything else cause it may be only a resistor or a capacitor but to replace it the guy that comes to do it will charge more than replacing it go to www.shopjimmy.com and check your tv model and it will give you what you need and the price and cheaper than the manufacturer
Posted on Apr 13, 2010
Emerson 32 HDTV LCD...my picture is smaller than the screen. How do I make the picture fit the screen. I'm missing a few inches of the images on both side...?
Most Emerson remote controls have a "FORMAT" button. Each button press cycles through TV Screen aspect ratio choices, such as Normal, Movie Expand, Wide, Zoom, etc. Pick one that fills your screen. You will probably have to change this setting again, depending on the signal source or channel selected.
The button cycles through the choices in a loop, so you can always get back to Normal.
Mar 24, 2013 | Televison & Video
Wont stop changing channels
Check and replace the main system memory IC. It is faulty. It is a very small IC, won't cost more. An eight solder terminal IC. Even though the physical size is small, function to it when the TV works is great. The work is a skilled one.
Jul 29, 2012 | Emerson LC320EMXF 32 in. LCD TV
My emmerson tv won't change to the channel i need so i can hook up my dvd
Is the player hooked to the cable/coax fitting or the audio/video jacks?
Apr 24, 2012 | Emerson Televison & Video
Tv won't stay on any one channel for any length of
I had a tv come in doing the same thing and a cap had been ripped from the circuit board I traced it back to the remote input from the front of the chassis. i havve no dea what value to but back so i have replaced it with several various fareds none work perfectly but some are better than others.
Sep 21, 2011 | Emerson LC320EM9 32 in. LCD HDTV
2005 32-inch GE color television--the problem is all of a sudden the television turned on by itself and started changing channels like crazy--we cannot stop it. When you first turn on the television--it...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jun 22, 2017 | GE 32GT720 32" TV
Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Mar 26, 2008 | Televison & Video
Emerson LC320EM9 32 in. LCD HDTV Logo
406 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
