Question about Bose Lifestyle 5 Music Center Ps3-2-1 Acoustimass Subwoofer & Cables 2 Speakers
Is it possible to wire my Bose PS3-2-1 II subwoofer with an my Onkyo TX-SR 309 receiver without the actual home theatre system? How; what wires, media cables etc. would I need?
A friend of mine gave the woofer, once they moved from the states as they had no use for it... the only problem was that no other parts of the system can be found. Was just wondering whether it possible to hook up this with my existing system.
SOURCE: No power to the Acoustimass bass
Hi, have you checked the internal fuse in your sub?
Posted on Dec 22, 2007
quang123
  • 107 Answers
SOURCE: Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Posted on Dec 16, 2008
SOURCE: connecting ipod to bose system
Look at the back of your 3-2-1 to see if the auxillary is a single or dual output. You will need that information when you go to Radio Shack, or you can also get at the Apple store, a connector from Gigaware that connects to the ipod. It was only $15-$20,
Posted on Mar 21, 2009
dunnbiker
  • 8546 Answers
SOURCE: how to hook up bose series 2 eq to onkyo tx sr 875 receiver.?
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! I see on the SR875 there are Pre Audio OUTS. This is easy.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Posted on Apr 25, 2009
SOURCE: How to use the Bose Acoustimass Subwoofer with other receiver...
I received a broken Bose acoustimass subwoofer... and by broken I mean the built in amp part didn't work. I don't have the module to control it either... and I wasn't given the unusual power cord so I couldn't even test it.
This is made in 1991, so I suspect it might be a series 1. It's in a white rectangular wooden box with a white plastic amp controller section up the top. It might be similar to the one you have.
Anyway, there was a little flap at the very top in the center and I removed a screw, then gently levered off the volume/bass/tone dials off with a flat screwdriver. I was then able to lever the entire top plastic outer box. I ended up just removing all of the circuit boards, heat-sinks etc. I won't go into the details but its a simple matter of undoing whatever screws you find and unclipping any joining cables between boards.
The power supply is mounted in a recessed plastic box that kind of sits inside the top of the box... I removed the power supply from the plastic box and set it aside.
Eventually I had the entire top section clear with a stereo cable coming out of the woofer. I snipped off the white connector at the end of the cable (that used to plug into one of the boards) and hung it out the top. I then replaced the recessed plastic box (that had the power supply) so that the top of the box was sealed again. I put the heat-sink over that just because it looked nicer (there are no electronics for it to absorb heat from). I made sure everything they were screwed down properly (so no undue vibration).
Basically I have now taken out all the electronic components leaving the driver in a sealed box, with the stereo cable still hanging out. I stripped some plastic off the ends of the stereo cable to expose the wires and attached a long stereo lead to the wires. I put the other end of the lead into the speaker out of my home stereo amplifier.
I started playing some music and it actually had quite a lot of bass. It wasn't too great at mid-range or high-end but it's not really supposed to as it's meant to be part of a 2.1/5.1/7.1 system. It will be good as part of any surround sound system.
Posted on Aug 21, 2009
Objects stuck inside subwoofer for Sony HT CT100.
Pull the front panel off very gently with cotton gloves. A peer of tweezer or nice shaped tonges should do the trick. Once removed-Place woofer up were children cannot reach
Feb 26, 2010 | Audio Players & Recorders
Stereo system in 1994 ford explorer
I had this same problem.Took it to a friend and we bypassed the amp completely and ran new wires to all the speakers.
Aug 25, 2009 | Dual XDMR7710 CD Player
...emailing to germany
Please check the exact error on the failure notice mail. If message states that it's "Unknown User" that means the email address of your friend is incorrectly type in. Ask for a valid email of your friend to correct this issue.
Jun 15, 2009 | Yahoo Mail
I try changing the LP filter switch off it will work but when i turn it on the bass controls won't work nothing will make the subs hit harder what can i do to make it sub harder
the bass controls bypasses the gain on that channel by using the control as the gian level so jus unplug the control and set the gain accorindly
Mar 27, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Subwoofer not working properly after a few mins playing
Get a hold of the woofer connector (I believe its brown) right by the whoofer and move it around/press it/disconnect and reconnect and check if the woofer comes on. There is a bad connection in the connector for the woofer itself. I have a 2001 GLE my self and that's what I found to be the problem with mine.
Dec 16, 2008 | 2001 Nissan Maxima
I HAVE JVC SURROUND SOUND SYSTEM MODEL SP-PWM 45,I HAVE LOST 8 PIN CONNETOR FROM MAIN AMP TO SUBWOOFER. WHERE CAN I PURCHASE THIS CONNECTOR THANKS
Here is a link to the system cable that I think that you are reffering to. The model number of the system you have is TH-M45
The model number you gave is for the sub-woofer only. This is the system cable that is required to connected between the sub-woofer and the main head unit with the DVD changer in it.
http://www.jvcservice.com/store/ProductDetail.asp?Part=QAM0381-001%20%20%20%20
If you can not click on the above link, just copy the entire link and paste it into the address bar of your interent browser.
Since this is the part you want and it is the cheapest place to purchase it, a rating of "FixYa!" would be appropriate and very much appreciated. After all, it is the only reward we get for offering people like yourself this free technical support.
Thanks,
Dave
Sep 12, 2008 | Pioneer 1000 Watt 5.1 Surround Sound...
Sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
May 15, 2008 | Audio Players & Recorders
Subwoofer
often your sub need to be change because of its malefunction.
Mar 09, 2008 | JVC TH-M303 System
Volume problem with surround sound
I tore mine apart, and the problem seems to be with the power supply in the sub-woofer-instead of 36 Volts, it it producing 2.6V. I'm having a friend have a look at the supply.
Sep 16, 2007 | Philips HTS3440/37 System
Bose Lifestyle 5 Music Center Ps3-2-1 Acoustimass Subwoofer & Cables 2 Speakers Logo
35 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
