Question about Honeywell 3800g Wired Handheld Barcode Scanner
My honeywell 3800g barcode scanner won't scan
The scanner just stopped scanning. I use the scanner for checking out books in a library. I downloaded the user guide and tried to scan the interface (PC) barcode as well as the Presentation Mode barcode. Can you help?
2 Suggested Answers
  • 34 Answers
SOURCE: I have a Honeywell 3800g Barcode Scanner with a
Most barcode scanners will not use a standard mini-din to USB adapter. You need to replace the cable with a USB cable designed for that bar scanner. Here is a Google shopping result for the cable you need. Good luck!
http://www.google.com/products/catalog?q=honeywell+3800g+usb+cable&hl=en&safe=off&prmd=ivns&biw=1419&bih=695&bav=on.2,or.&wrapid=tlif129971812876510&um=1&ie=UTF-8&cid=1100600390771774037&sa=X&ei=_B94TdetEI6NrQG6p5nuCQ&ved=0CF0Q8wIwAA#
Posted on Mar 10, 2011
Honeywell Barcode Scanners configure for Excel
Find solutions to your Honeywell Barcode Scanner...ask an expert to help you find the right scanner for your application. Honeywell Barcode Scanners for handheld and handsfree bar code scanning
Jan 22, 2014 | Honeywell 3800g Barcode Scanner PN...
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
Barcode Scanner stopped scanning
These devices do fail, so that is most likely what has happened here.
Apr 13, 2017 | Honeywell 3820 Wireless Handheld Barcode...
Need installasion instructions as well as program
Hi
Click hear to find the manual read the manual and install the your HoneyWell 3800G
Jun 08, 2011 | Honeywell (formerly Hand Held ProductsHHP)...
My 3800g barcode scanner puts a prefix of ~% before the UPC number. I'm sure the answer is somewhere in the 156 page manual, but to a non-technical guy like me the manual may as well be written in...
Hi
If you have the user guide then go to the page 48(4.3) there all option available, To clear the perfix and suffix, other wise download the user guide to Click hear
May 26, 2011 | Honeywell 3800g Barcode Scanner PN...
Hi, I am trying to install the drivers for my HandHeld 3800G Linear Imager (barcode scanner), but keep getting the following error: "Cannot Install this Hardware There was a problem installing...
you may have to delete the file or uninstall-then reinstall..if this does not work you may have to go to the honeywell site and reload the drivers again as you may have lost a thread during the initial download ...happens more than you think...good luck
May 19, 2017 | Honeywell (formerly Hand Held ProductsHHP)...
I have a Honeywell 3800g tethered barcode reader that has been working fine on the same computer for approximately 3 weeks. It has been used to scan patient ID bar codes and drug NDC numbers in our...
It's a USB scanner. Maybe you accidentally scanned some rogue barcode that changed the default symbology to something that you can't use in Meditech. I would start troubleshooting basically with this. On the PC where it no longer reads into your Meditech software, try to remove and re-insert the USB cable on both ends - scanner and USB port. Next, ensure that the scanner's driver is set to use this HID (human interface device) as a keyboard emulation device. Next, get (or download and print) the manual for the device, because it has barcodes for changing scanning settings, symbologies, etc. Scan the barcode that says "Reset to default settings", then try scanning again. At this point, if you still cannot get a reading in the Meditech software, try to specify the correct symbology for your medication barcodes. If you still have issues, try a different USB port on the same PC. If still issues, try a different PC. If it works on Meditech on another PC, perhaps you need to update your Meditech version on the bad PC to match the version that works. If all else fails, exchange it for another one; perhaps it truly is defective. I hope you can get up and scanning again!
Edit: I just realized this scanner has more cables than just USB. Are you using a wedge? If so, what kind (PS/2, RS232 (serial) interface, etc.)? There is different troubleshooting for PS/2 and RS232.
Mar 24, 2017 | Honeywell Office Equipment & Supplies
We recently received another 9520 from Honeywell to replace a faulty one. For the non-tekkie, how do I configure it for use with library scanning for books?
Bar Codes The MS7120 can be configured by scanning the bar codes located in the MetroSelect® Single-Line Configuration Guide. This manual is available for download at http://www.honeywellaidc.com/site.aspx/na/en/product_center/product_support/?category=5&product=297
Please let me know if you need further assistance
Kim Ganoe 800.933.2839 x251.
Mar 23, 2010 | Microsoft Metrologic MS9520 Voyager...
Honeywell 3800g Wired Handheld Barcode Scanner Logo
100 people viewed this question
Top Honeywell Computers & Internet Experts
Ron Dufek
Ron Dufek
Les Morrison
Les Morrison
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
