Question about Sony STR-DE475 Receiver
Sony STR-de675 always in protect mode only when plugged into power
SOURCE: SONY STR-DE675 RECEIVER
Protect mean that the speaker wires are touching eachother or that one of your speakers are blown and it is shorting out the receiver.
Posted on Dec 24, 2007
urnotjoeking
  • 5 Answers
SOURCE: StR-DE945 stuck in auto protect mode
I had a mechanical problem with the relay on the 1st power supply board. The relay right next to the small transformer. The blac cover for the relay just comes right off. Make sure that the little black plastic piece is still in position (you'll see what I mean when you open it.) and check the contacts on the relay.
Posted on Jan 24, 2009
ginko
  • 19396 Answers
SOURCE: stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
smarthome2
  • 1114 Answers
SOURCE: i have a sony str-500 and when i plug it in all it
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jan 30, 2010
dunnbiker
  • 8546 Answers
SOURCE: Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
Posted on May 21, 2010
Testimonial: "@dunnbiker Very true on assumptions! I've tried everything the manual suggests. Right now, nothing is connected to the unit, but upon power up, I get the SP:OFF display (which is not seen in the DEMO mode). I will try the headphone jiggling idea and see what happens."
Need remote control programming codes
I assume you have purchase a universal remote control...if the programming codes for your Sony STR-DE675 receiver is not listed in the remotes code guide, then you purchased the wrong type universal remote. Make sure you get a universal that does stereo equipment or check eBay for a reasonable price on the original.
Jan 07, 2014 | Sony STR-DE675 Receiver
I cant power it up when i hit the power button
try to check the plug.,,, unplug then plug it again then try to power it up...
Apr 27, 2011 | Sony STR-DE675 Receiver
Hi, I have a sony STR-DE675.; the audio cuts out between stereo and mono, as if something inside is heating up.I have cleaned all connections and carefully vacumed out any dust from inside the unit.The...
STR is a very sensitive ic module of the audio system and it always has a tendancy to heat up quickly and has some basic precautions to be maintained for operating this. correct speakers should have been connected so on..
if you are technically very confident open up your system try to locate the str ic unit check whether the contacts of the heat sync (aluminium metal chunk screwed with the ic to absorb the heat) has been correctly fixed. (pls note- manufacturers will always have appropriately heat synced it try to use it in a cooler place)
Feb 01, 2011 | Sony STR-DE675 Receiver
Str-de685 WHEN I POWERED I HEARD A CLICK BUT EVERYTHING OFF NO LIGHT.I CHECK BOTH FUSES AND ARE OK.
There is a relay on the power supply circuit board that might be faulty or has bad solder connections. If this relay does not work, power is not applied and everything is "dead". I had to re-solder the speaker relays on my STR-DE675 because they had cracked solder joints which made them work intermittently. It's possible that the power relay is what is causing your problems. If it has bad solder joints it might click, but power might not be able to pass trough the joints.
Does it still click when you turn it on or did it only do this once?
Dec 01, 2010 | Sony STR-DE675 Receiver
May 21, 2010 | Sony STR-DE675 Receiver
Is the STR-DE675 5.1 Surround Sound Receiver compatible with P.C.
Sure! Any P.C. with an audio output jack, like an 8mm phono jack to stereo for example, can be connected to any audio input on the receiver.
May 13, 2010 | Sony STR-DE675 Receiver
Sony str-d715 flasses protector
May 03, 2009 | Sony STR-D700SS Shelf System
Sony str-de675 cuts out in dts mode
Your optcal line may have a break in it ! try another opt cable or try useing the digital cable out!
Dec 13, 2008 | Sony STR-DE675 Receiver
Help
check/replace your speaker wires. If a wire came loose, it will go into "protect" mode and shut down, to protect from a short circuit.
Jun 16, 2008 | Sony STR-DE525
check the speaker's connections, I got them message when a speaker wire was unplugged and plugged back in while the unit was powered on
Oct 02, 2007 | Sony STR-DE675 Receiver
Sony STR-DE475 Receiver Logo
70 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
