Question about Clarion Radio Model Pn-9945m
Wire diagram for pn9945m
Need wire diagram to hook up anotehr radio in this vehicle cant find pos
2 Suggested Answers
  • 26 Answers
SOURCE: I need a wiring diagram
First you will need to get a wire harness for your specific make, model & year of car. This will interface the car wiring plug to your new clarion headunit.
Next you will connect the wires from your purchased wire harness to the wires of your Clarion Headunit. Using **** connectors with a wire crimper is the best way to do so.
Here is a wire color coding guide for the wires on your Clarion headunit:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Posted on Mar 17, 2011
Re Clarion radio screen brightness, I have retro fitted the radio to another vehicle but the wiring diagram doesn't mention a dimmer. Do I need to hook one of the wires into the headlights?
One of the wires on the radio is for the brightness. Connect this wire to one of the dash lights that dim with the dimmer control or the headlight switch dimmer if your vehicle is equipped that way.
Sep 12, 2016 | Cars & Trucks
Where could i fond the wiring diagram for my Kenwood Excelon KDC-X592 Car CD/ MP3 Player?
There are vehicle - specific adapter plugs for after market radio hook ups. These adapters are used to connect the original plug that was connected to the original radio with the new radio's plug.
You didn't list what vehicle you have, year, model. You can do a web search with " (year and model of vehicle) radio wiring adapter".
Hopefully you'll find the adapter for your vehicle.
May 28, 2014 | Kenwood Excelon KDC-X592 Car CD/ MP3...
Wiring diagram
Hook up the trailer to the vehicle. Under the rear bumper you will find a thick wire harness that runs from left to right or vica versa. Choose a location to strip open the harness to gain access to the different color wires. Open the trailer coupling. remove all wires and split them apart. Now start with say the right indicator light on the vehicle. Earth should be established via the grounding method of the trailer hook steel on steel of the vehicle. Connect any wire of the trailer to the now flashing right indicator light. Go through them all till the right indicator bulb flashes on the trailer. A good approach to determine which wire is active, is to make a test light from an old bulb connector some have already two wires connected ie; pos neg. neg the tester onto any part of the vehicle chassis and the pos to the now live wire. Go through them all till all wires meet up. Now go on and extend the harness by means of soldering properly and insulating that wire from the main harness to the female fitting of the trailer connector. At each connection on the fitting fit on properly the different wires and do the same to the male connector from the trailer so that all lines up inside the two connectors. Good luck
Aug 14, 2013 | 1993 Land Rover Defender
I need the wiring diagram for a dual stereo model xd1225 to hook it up to a 1986 ford f150
OK, for starters, get a wiring harness made for your vehicle. All aftermarket radios have standardized wiring colors. You wiring harness will have matching colors, so it will be easy to hook up. The harness will also have the diagram of colors on the package. However, you vehicle wire colors will not match this. That's why you have the harness. You will just plug into the stock vehcile harness. You will not have to match any wires because the harness is specifically made to match your vehicle. Trust me, it's easier this way. You can find them all over, try www.crutchfiedl.com to get one if you need. Hopd this helps.
Aug 23, 2011 | Car Audio & Video
I need Only color coding for wiring diagram for cdx-gt550
If you are planning to install your radio, I recommend you purchase a wiring harness specific for your vehicle. All aftermarket radios are standardized in wiring colors. The harness will have the diagram to hook your radio to the harness. The problem with hardwiring a radio is the wiring colors don't match, and hooking it up wrong could fry your entire electrical system. You can find a harness at www.crutchfield.com Hope this helps.
Hi just looking for Radio wiring diagram so i can hook up new cd player myself.
HI All vehicle brands have different wiring, as do different models. If you list what vehicle you have I should be able to give you a specific wiring diagram. The new source unit that you have, should either have a diagram for its wires on the top of the unit or in the units instruction manual.
Im sorry for not being able to help more but there is no generic vehicle wiring diagram
cheers
Jan 11, 2011 | Car Audio & Video
Need wiring dig. for a 94 f150 radio
yel acc
lime green 12volt pos
blk ground or red
orange\grn left pos
blk/grn left neg
whi/grn right pos
blk/whi right neg
blue /red illumination
Mar 16, 2010 | Car Audio & Video
Need wiring digram for road king 56 to cobra 29 cb
He is actually looking for the Microphone wiring which is a roadKing Mic to the Radio Cobra 29.
Apr 23, 2009 | Magnum DeltaForce CB Radio
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
Clarion Radio Model Pn-9945m Logo
82 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
