Question about HP Compaq Presario V6000T Notebook
Wireless not working
I have a compaq laptop and I was browsing the internet earlyer and the wirless was working fine, but then 10mins later the wirless icon had vanished and the switch on the front of the laptop itself is not switching the wireless on as the light is staying orange. My dad has reterted the whole system but has had no effect so he may think the wireless card or something has gone. Do I need to take it to a computer shop to get it fixed, as the problem is that I am a student so I don't get any money to get the wireless fixed and I need it to do my work and reasearch on.
  • Anonymous Feb 08, 2009
    I can get through everything except cannot locate wireless network connection to uninstall.  Any suggestions?
  • 4 Answers
Go to control panel click on system, navigate to hardware then to device manager than click on network adapters than right click on ( wireless network connection) and uninstall it, than restart computer and it will find new hardware. Click on new hardware icon and open available wireless networks and select network than connect.
Posted on Jan 26, 2009
Compaq presario m2000 blue wireless light doesn't
You should have re-installed the Driver for the Wireless Card, you can do that by going to Control Panel, than clicking on System and Maintenance, and than going to Back Up and Restore, go to Repair Windows using System Restore, you can re-install your Driver that way or go to www.hp.com and go to Support, enter your Model #, and you can re-download your Driver from there.
Jul 12, 2010 | Compaq Presario CQ60-220US PC Laptop
Compaq Presario F730US PC Notebook: i installed hp wireless assistant. but when i open...
I used to have internet wireless connection problems and finally realized that F761usa front wirless swich was changed frequently, even I believe I never touch there.
May 17, 2010 | HP Compaq Presario F730US Notebook
Want to get on internet with my lap top via wireless what card do i need for the inspirion 8100
first of all you need to check with your internet provider to see what modem you can use. a wirless 802.11g card (the farthest range) if your provider has a wirless modem i would get it from them. and a wirless modem/router. i use bellsouth wirless dsl and bought the equipment from them. if you have a wirless modem/ router already then you just need the card and configure it.
Jul 26, 2009 | Dell Computers & Internet
Wireless Internet for compaq Presario
Check out the wireless setup manual for your laptop here:
http://h10032.www1.hp.com/ctg/Manual/c00065819.pdf
Hope this helps!
Mar 28, 2009 | Computers & Internet
Compaq evo n800 laptop built-in wireless internet
right click "my computer", left click properties, select "Device Manager" Expand anything to do with "Network Adapters" and make sure there are no problems / exclamation marks / unknown devices.
If there are, look for your wireless driver on..
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=compaq+evo+n800&submit=Go+%C2%BB
depending on your model. if this doesn't work go to www.hp.co.uk and download the driver then install it.
If you can't detect any wireless networks, make sure your wireless card is activated - I believe this involves holding down FN (bottom left of keyboard) while then pressing F2 key at top. after this try try to search for wirless access points points.
Good Luck,
Cheers,
Colin
Mar 18, 2009 | HP Compaq Evo n800c Notebook
D-link air Wirless CompactFlash 802.11b Wireless Solution
have u configured it if yes that the job of ur i.s.p to make it browse cos they have all the necesary info like ip that will make it browse so contact yr isp.
tnk u
May 26, 2008 | D-Link AirPro DWL-AB650 802.11a, 802.11b...
Audio and Wirless driver for compaq c700, model - C765TU
I'm looking for a Wirless driver for compaq c700, model - C765TU. Pls help
Thank you
May 25, 2008 | Compaq Presario 700 470024-192 Notebook
Wireless connection lost
Wirless and modem systems both are different, there is no connection between them.
If you were using your modem for internet access then you should chek-out your modem and phone-lines etc. Wirless will not effect.
verify your modem driver is installed correctly and check the settings.
Thanks
Iqbal
Apr 06, 2008 | HP Compaq Presario V2000 Notebook
Wirless not working
I"m almost sure that I answered this one already..
Mar 11, 2008 | HP Compaq nc6320 Notebook
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
HP Compaq Presario V6000T Notebook Logo
114 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
