Question about Harman Kardon Audio Players & Recorders
SB30 subwoofer makes poPping soUnd - Harman Kardon Audio Players & Recorders
2 Suggested Answers
  • 124 Answers
SOURCE: 15 inch velodyne subwoofer making a loud popping sound
If you have changed the signal source, then these may not be the problem at all, it may be that you have the sub output set to low on your processor.
This may be one of these problems.
It could be the "auto on" circuit.
If you change the switch on the back of the unit to always on does it still do this? if not then it is the auto on circuit that is the problem.
The driver mounted servo unit is starting to fail.
A cap in the amplifier input section may be going bad.
You nwill need to contact Velodyne for repair of the unit.
Posted on Mar 28, 2009
How do I connect my Sharp HT-SB30 soundbar to Samsung UHD7500 TV
Should be able to use Bluetooth. Need to "pair" the devices (the TV and the soundbar). On soundbar, press On/Standby to power it on, press Input to select Bluetooth (pairing indicator blinks), press & hold pairing button until pairing indicator blinks quickly. Now go to the TV's setup menus: Sound > Speaker Settings > TV Speaker > SoundShare Settings, Add New Device=On, select the Sharp GT-SB30 from device list. If passcode, password, etc is needed, enter 4 zeros (0000). After the devices are paired. the pairing indicator on the soundbar should stop blinking. The pairing information should be retained so you only have to do this one time unless you do a full reset on the TV or soundbar.
Dec 23, 2014 | Samsung Audio Players & Recorders
Jbl subwoofer pops
Check the power socket you use ,if the grounding is not proper or if the wiring to socket is not wired with correct Live& neutral - should be the issue ,atleast 80% of the time it is this.. Ohh yes also the output from the system see if its connected properly or broken...
Aug 18, 2014 | JBL SCS135 System
Enter chat room
Hey there it seems to be a common problem with this model and there have been many complaints about it. Harman are saying that the sound boards are made in China and they are using inferior components. they rekon if ya get in touch with there spare parts department they will send you out a new one.
Nov 17, 2017 | Harman Kardon Audio Players & Recorders
My Sunfire MKll is making a popping/rattling sound during some low frequency notes, the sound is coming from the left woofer when facing the amplifier board ( its the softer woofer of the two, but...
The passive radiators on those are notorious for coming apart inside and making a knocking noise. You can sometimes glue it back together but youll have to remove the driver from the cabinet.
Jul 30, 2012 | Sunfire True Sub MK II Subwoofer
My pb10 subwoofer makes a popping sound and does not play the music
Item can be fixed - ship it to Edwards Electronics - Look For US On Ebay - Thanks
Mar 07, 2011 | JBL PB10 Subwoofer
Subwoofer
turn on the amp and you know that the amp is good and you hear nothing
1. paralell wiring on speakers that are the wrong impedance very often will silence speakers to a eternal sleep along with that amp.
2. 4 ohm speakers mistaken for 2 ohm and are 8 ohm speakers mistaken for 4 ohm, the amp sees this load and it causes a overload on either side of the amp internal filter
( that's what makes the "pop sound") amp pops inside, literally makes a "pop" sound
you get a no sound
Oct 20, 2009 | Car Audio & Video
Feb 20, 2009 | Velodyne HGS-15 Subwoofer
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
247 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
