Question about Toshiba Computers & Internet
Function key not working on Toshiba Satellite A350
FN key doesn't work on keyboard, can't connect to wireless
tparsenault
  • 170 Answers
SOURCE: KEYBOARD - FUNCTION Fn
Mine is fn with f4
Posted on Feb 10, 2009
SOURCE: Keyboard stuck in Fn mode
had the same prob on my laptop which doesn't have a seperate number pad so all I needed to do was to press "Num lock".
Posted on Apr 27, 2009
sp4m771
  • 116 Answers
SOURCE: toshiba satellite fn key display problem
Just download this :) It will fix your problem. If it doesn't work, just search for Toshiba Value Added Package Vista/XP (that depends on what Operative System you've got) and download for your Operative System.
Posted on Jul 23, 2009
SOURCE: Some of my function key shortcuts have stopped working
go to asus website and click support. after that click download and find the ATK file...I tried both, but I believe the larger file is the one working
Posted on Dec 18, 2009
SOURCE: FN key not working in Toshiba Satellite
Hey,
Try to install these utilies:
Toshiba Common Module
Toshiba Hotkey Utilities
Toshiba Touch Pad ON/Off Utilitiy
Toshiba Utilities.
... in the same order and reboot between them.
One guy posted it on some Forum.All credits to him :)
Hope it helps.
Posted on Mar 04, 2010
Wireless not enabling
Silly question, but are you folding the "Fn" key (bottom left of keyboard) down at the same time as you are pressing the "F12" key?
Apr 29, 2013 | Computers & Internet
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
Jan 09, 2013 | Toshiba satellite c660
IBM T30 wireless and graphis driver
it might be that your wireless is not activated or disabled. look for a key on your keyboard which has a wireless picture on it,then press that key with the Fn (function) key at the same time when you're on the desktop. or if it's still doesn't work,the network you try to connect is not available
for the video driver,you can download it here
http://support.lenovo.com/en_US/?template=/product.do?template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&sitestyle=lenovo&brandind=10&familyind=99273&machineind=99914&modelind=103950&partnumberind=0&subcategoryind=0&doctypeind=9&doccategoryind=0&operatingsystemind=53385&validate=true
Aug 26, 2012 | IBM ThinkPad T30 2366 Notebook
The fn keys dont work in my asus except for the fn+f7 one. when i press fn+f2 the led light goes on and off but it doesn't seem to work??? what should i do??
Hook a external keyboard to the laptop, if all functions checkout. The keyboard in the laptop will need to be replaced..
Mar 30, 2012 | ASUS Computers & Internet
I have spilled water on my laptot and the keyboard doesn't work anymore. I have connected an external keyboard now however, I cant switch on the wireless capability. Does anyone know a way to do t
There may be a switch on the side of the laptop that turns the wireless on and off. Also try pressing and holding the fn key and pressing and releasing f1 or f2. The water spill may have killed the wireless card also. If you still can't get it working, then purchase an inexpensive usb wireless adapter. This will plug into an available usb port and will give you wireles capabilities. You will need to replace the keyboard as well as it was obviously damaged by the spill. Check on ebay, or contact the manufacturer for a replacement.
Hope this helps!
Joe
Mar 25, 2012 | Fujitsu Siemens (AYU0N1090ED00103) PC...
Lenove ku-0989 fn key
  1. Numerous folks indicate that Windows doesn't register the Fn key as a keypress but using a tool that gives the ASCII value of a keypress I see the Fn key returning FF (perhaps FF in this case means 'not registered'). I also see that keys like Ctrl register with one ASCII code when pressed alone and another when pressed in combo with another key. Fn will only register when pressed alone, so Windows definitely isn't seeing the combo. This took a solution like AutoHotKey off the table.
  2. I ran KeyTweak (which shows you the hardware scan codes of a keypress and the Fn key registerd as 57443). Using this program I remapped Fn to the Ctrl key; this worked perfectly. However, I suspect that because of the issue in #1, the combo of, for example, Fn + C did not execute a copy.
Nov 22, 2011 | Lenovo Keyboard
It will not connect to wireless, it keeps saying turn on wireless communication switch yet there is no switch on the computer. I have been without a computer for almost a week, please help!
@kblossom1280
There's two switch to turn the wireless capability of this laptop:
1. You need to turn ON the physical wireless switch located at the top of the keyboard (see image below)
2 If that doesn't turn the Wireless ON, you need to press the Fn+F8 key (the Fn key is located on the left side of the space bar).
Good luck.
Sep 07, 2011 | Toshiba 14 Satellite M645S4114 Notebook PC
I have problems with the wireless, the laptop is Ok.. and suddenly the internet is gone, and the little orange light is off, but the laptop doesn't have any button to turn it on again... and I have to...
Look at the keyboard at the Fn keys..........one of the is probably the wireless...locate the key and depress Fn and that key together and wireless should come on! Could be F4?
Jul 24, 2011 | Computers & Internet
Hi I have just bought an Acer Aspire Z5710 all-in-one PC. I find the screen too bright when working for long, and want to adjust the brightness. But i am not able to figure out how to do so. And there...
http://support.acer.com/acerpanam/Manuals/acer/2011/ServiceGuides/SG_Aspire_Z5700_Z5710_20100907.pdf
If the keyboard doesn't have a Fn key often the Scroll Lock key is used, try Scr Lk + Down arrow to dim the display.
The manual indicates and Fn Key to the right of the Left Alt Key but that doesn't mean you have that keyboard eitther
Jun 30, 2011 | Computers & Internet
Computers & Internet Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
