Question about Toshiba 32SL410U 32 LCD TV
I have a toshiba tv 32sl410u with remote ct-90325 and you cant change channels with the up and down button
Theres a code that we don't know blocking it. it will change by punching in the numbers
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
SOURCE: Toshiba 50HP66--can't change channels anymore
I had this problem. Unplug it while it is powered on. Worked for me.
Posted on Nov 03, 2008
SOURCE: Toshiba Remote #CT-847
where can I get the manual for a Toshiba ct-847 remote
Posted on Jul 31, 2009
jyackle5
  • 8197 Answers
SOURCE: I have lost the manuel
You can learn how to program the remote on the link below page 12
http://tacpservice.toshiba.com/consumerproductsupport/manuals/tv/2004/32A14.pdf
Good Luck
Posted on Dec 07, 2010
Ironfist109
  • 3018 Answers
SOURCE: I lost the remote to
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jul 20, 2011
HOW TO CHANGE INPUT ON TV
Go to menu and set up section, should give choice of inputs.
Feb 16, 2015 | Toshiba Original CT-90325 TV Remote...
Need pin code for Toshiba tv 32SL410U or how to reset the code
If the TV has a password you do not know and you want to change it to a password you know so you can make changes to the TV settings (such as removing the password entirely):
  1. Press the Info or Recall button 4 times on the remote control.
  2. Enter a new password when prompted.
Jan 30, 2015 | Toshiba Televison & Video
How do I program the Toshiba CT-90325 remote to control the Toshiba SD-V280 VCR/DVD player?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 23, 2014 | Toshiba Original CT-90325 TV Remote...
How do i enter codes on a toshiba ct-90325
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
Jul 22, 2014 | Toshiba Original CT-90325 TV Remote...
My remote Ct-90325 for a toshiba tv keeps saying not available when I press any button
My only suggestion is to read the owner manual to see if the set has a lock out feature that stops the remote from doing any functions.
Jun 13, 2012 | Toshiba Ct-90302 Remote Control
My remote CT-90325 is saying not available when I use it to turn on tv
The remote control do hot recoganize the set. You have to setup it with your TV by using setup codes. You haven't given any details about your tV here. Then, how can one post a solution to your problem?
Jun 13, 2012 | Toshiba CT-847 Remote Control
Toshiba ct-90325 remote will not work
I seemingly had the same problem, it just wouldn't turn on the tv or do anything for that matter so I popped the controller open to have a look and noticed that there was a small square box capacitor where the "cheap" metal that was making contacts with the circuit board had broken so I re-soldered the broken pieces and voila it worked. Cheers I hoped this helps some of you that have this same problem.
Jan 16, 2012 | Toshiba 32A41 32" TV
I cant figure out which button is for the code search on this remote
It should be channel up button. Just keep pressing it, allowing 3 seconds in between presses. Once your television turns off, you have found the code. Then press enter, and try turning your television back on. (Note: not all televisions will power down. Some may only change the channel)
Nov 04, 2009 | Toshiba CT-877 Remote Control
Toshiba 32SL410U 32 LCD TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
