Question about Samsung Cadence VM8A 8 Port Voicemail Prostar DCS
How do you purge/delete mailbox from Samsung DCS Cadence VM8A card? We bought a used one and I have numerous users who are trying to setup their mailbox and it's saying invalid passcode. Should be 9876(Default)
4 Suggested Answers
  • 3 Answers
SOURCE: samsung phone
Chances are that virgin have locked your phone so that no other sim cards from other mobile networks can be used in it. You need to get your phone unlocked, which can be done either by virgin (which will be expensive, around £40) or you will probably find some store on your local high-street that will do it at a cheaper rate (normally around £10). When your phone is unlocked, you will be able to put any sim card in it, no matter what network it is. Hope this was useful!
Posted on Jan 23, 2008
Bajanguru
  • 7752 Answers
SOURCE: memory card
the card could be faulty try another 2gb and see if that works if that does not work.......then you may need to reset the phone *2767*3855#
Posted on Oct 25, 2008
  • 55 Answers
SOURCE: Samsung Propel unlocked but now frozen
if you have ATT then call them and tell them your problem. they have all the access and unlock codes to every phone they make! as a matter of fact they can tall you more about your phone than any one person on here. please write me back and let me know what they say
Posted on Jul 08, 2009
We have a KX-T7630 phone and we are trying to reset mailbox password but it won't work. We tried to delete password by accesing mailbox 999. We went to Other features Mailbox Setup . Reset Pas
You need to set a specific password. Probably in RESET password, it's reset to a default value, so if you don't know what the default is, then you can't use it. We usually use x(plus your extension), where x is like a digit 3 or 4, but I didn't install yours :-)
Carl
Aug 02, 2012 | Panasonic KX-T7630 Corded Phone
Won't record voice mail. Never says recording and then says good bye
Hi this sounds like your mailbox needs re-setting up, so you need to find a Samsung Telecoms Engineer, I've posted a video to see if this helps with the other voice mail users. Visit
http://abbeytelecom.com
Sep 29, 2010 | Samsung Prostar DCS-24B-STD Corded Phone
GOOD DAY HOW CAN I CHANGE THE PASSWORD TO A MAILBOX ON A SAMSUNG DCS (SVMI)
to change your password for your mailbox on your Voice Mail, dial into your Voice Mail, enter your password then press # , this takes you into personal services, the prompts will talk you through changing passwords etc for Voice Mail. I have posted a Video with Voice Mail hints and Tips , there are more like this on Youtube search 'abbeytel' or go to www.abbeytelecom.com. I hope that this helps you.
Mar 30, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
Memory full
http://www.home-electronics.net/ge/pc/user-manuals.asp
Try this site.... personally, I could not find your exact model number. Hope this helps somehow.
Aug 20, 2009 | GE 27928GE2 Cordless Phone
Samsung iDCS 28D Voicemail Problems
If you have administrator access use the following steps to change the code:
Access the Administratin Main Menu and select 4 for mailbox programming.
Select the mailbox to program. Dial option code 1402. The current value will be played. To hear the current value press 1, to enter a new value press 2, to hear the range of valid values press 3. Press 2 to enter new value. Enter the access code for the mailbox. The value you entered is played back. Press1 to save or 2 to re-enter. Press 3 to exit without saving. Press # to exiit or hang up.
Aug 03, 2009 | Samsung DCS 12 Corded Phone
I have a samsung phone system lcd 12b and I need to re-record the message callers here when we are closed or cannot answer but I don't remember how Please help!
to record greeting on the Samsung DCS;
To enter voicemail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voicemail message, you must press 3, delete the original message and reset the message followed by the #. Please take time to watch the video I have uploaded for you which relates to the DCS Voice Mail. There are 67 more like this on youtube under 'abbeytel' or go to
http://www.abbeytelecom.com
Jul 03, 2009 | Samsung DCS 12 Corded Phone
Old Unknown Password for Voicemail
Unfortunately the passwords can not be seen and the only solution is to delete the mailbox and re-install it. Your Admin Assistant should be able to add and delete mailboxes. Sorry, Let me know if you need help with deleting and adding the mailbox. .....Mitelmike
Oct 13, 2008 | Samsung Phone PDCSLCD12B
Samsung DCS Basic 12B phone voicemail
I assume you forgot the passcode to a voicemail box , not the pass code to the voice mail system. The easiest way to fix your problem is to enter voice mail programming(from a telephone) and delete the box and then create the same box again. That way the mailbox when created will come up with the system default pass code
Sep 10, 2008 | Samsung DCS 12 Corded Phone
SAMSUNG DCS 12 OR 24 LCD HAVE (answer machine emulation)
Depends on your vmail system and telephone system. If you have a cadence vmail or svmi-8, you must go into system programming on your telephone system and program the key on the phone.
Jan 16, 2008 | Samsung Prostar DCS Phone
Samsung Cadence VM8A 8 Port Voicemail Prostar DCS Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
