Question about LG WM2487H Front Load Washer
Lg f1443kd out of balance load error - LG WM2487H Front Load Washer
LG wash machin have error code "EU"
There is no such error code. The closest error code would be UE which means that it's a unbalanced load error. If you have a light load, or you are washing a large bedsheet or bedspread, that will cause it to not spin properly because the machine cannot balance the load. The best thing I can recommend is adding about 4 to 5 large bath towels so the weight can be distributed more evenly.
Good luck
Jun 12, 2011 | LG WM-2277HW Front Load Washer
My lg Tromm front load washer had a UE error code. I know this is for an unbalanced load but I turned off the machine. Once I adjust the load balance, how do I get it back to the spin cycle
these units have had alot of problems especially if it is on a pedistal ...they won't admit this is a problem but i have been a lg servicer for over 4 years now and see it everyday ...the unit has a stator on the rear of the tub and on the stator is a device called a hall sensor that goes bad very often... it is what controls the spped and balance of the tub..if the load starts getting unbalanced the hall sensor will tell the motor controller to slow the speed down... most likely this is your problem.... good luck please vote
Jan 03, 2011 | LG WM2016C
My LG F1443KD washing machine keeps saying load out of balance even when it is empty on a calc cycle. Help!
See here for a solution http://www.amazon.co.uk/product-reviews/B00364KPZ2
Dec 04, 2010 | Washing Machines
Lg inverter 75kg wd1238c problem, after before getting to the spin stage of the wash, it stops and the screens says UE on it and UE is flashing on and off
Error code UE cause : Load is too small, load is out of balance( 1 or 2 large items) solution: Add items to help balance the load, rearrange load to allow proper spinning.... Hope this is useful .....
Sep 18, 2010 | Washing Machines
WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
May 16, 2010 | LG WM1814CW Front Load Washer
LG Washing Machine won't spin, signals that load isn't balanced
Check the drain clean out at the drain pump. If is cloggedm with debris, it will not spin and go off a a long drain error code.
Feb 06, 2010 | Washing Machines
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
Error message displayed on LG tromm washer model # wmt2778w
Flashing UE - The display shows:
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
Nov 07, 2007 | LG WM-2277HW Front Load Washer
LG WM2487H Front Load Washer Logo
65 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
