Question about Edirol R-09 Digital Voice Recorder
Edirol R-09 won't try to make USB connection to computer
Not only does the computer (an iMac) not recognize the R-09, but the screen on the R-09 doesn't even indicate that it's trying to make a connection.  I've tried using various USB ports, factory reset, making sure it's not on playback or the finder screen, etc.  Any ideas?
  • 6 more comments
  • fmdolan Jan 29, 2009
    I don't have a pc. I did download the update, but I can't update the recorder unless it's recognized by my computer.
  • fmdolan Jan 30, 2009
    I got a new cable, and it still doesn't work. Someone suggested that the driver disappeared from my hard drive, but I can't find it anywhere to download.
    I also tried different sockets, and tried different devices so I know the computer sockets are OK. It used to work on my mac, but I did once have to re-install the system so perhaps I lost the driver then. The question is, where can I download it? I can't find anything on the Edirol site.
    I got a new cable, nothing seems loose.
    Thanks, but this protocol doesn't work. And I really don't think it can be the recorder itself -- it records and plays back without any problems.
    Thanks, perhaps I should just take it in for repair, but what do you think of the suggestion that the computer lacks the proper driver?
    The cable is fine, and the connections on the mac and the recorder are fine.
    No the cable and connections are fine. Thanks for your suggestions but I think it must be a driver problem. I just wish I knew where to get a driver.
  • 19,396 Answers
  • 139 Answers
Try uninstalling usb controllers or go for a fresh installation of USB drivers
Posted on Jan 30, 2009
    Genius:
  • 1,913 Answers
Remov ememory card and battery then attachagain .also u say that u reset all settigns to factory defaults if not reset again.then connect in usb.if other device works fine then your computer usb has not problem .also see in recorder that your usb option is enabled.
    Master:
  • 416 Answers
1. The problem is that USB cable is not fully inserted into USB port of the recorder, some of them can get stuck on half way. Try to reinsert it and check the connection
2. Also check the menu settings the USB function might be locked.
Good Luck
  • 1,800 Answers
Check:
  • the usb connector of ur device.resoldering required in this case.
  • the usb connector of the iMac.
  • check the usb cable.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
May I offer an alternative perspective? It is a hardware fault internal to the Edirol R-09. Any USB connections has only 4 wires involved, +5, GND, Data + & Data -. In the same token, USB connector of the R-09 would have only 4 pins and 4 connections inside. Since:
  • the Edirol R-09 does not recognize the USB connection;
  • the computer does not recognize the USB connection;
  • a different cable is use to establish the connection;
  • other USB devices work in the same USB connection.
Which eliminates all other possibilities other than the Edirol R-09 itself.
I am therefore inclined to think that if Edirol R-09 still works except the USB, then it's internal connectors are disconnected or a cold solder issue is the problem. Should this hold true, then solution is re-soldering or replacing the Edirol R-09's USB jack and/or its internal connection/wiring.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 30, 2009
    Agree on seeking tech services or even a buddy who has soldering experience.
    computer lacks the proper driver? even if it were so the the R-09 would show something like what you posted "the screen on the R-09 doesn't even indicate that it's trying to make a connection", whether the computer has the correct driver or not.
  • Louie  Role
    Were you able to see my comment re the drivers?
  • 360 Answers
Thanks for using FixYa, try this solution
Print these instructions and follow them exactly as written.
correcting problems using Mac OS
1. Turn off your computer, not standby, off.
2. Turn off your R-09.
3. Wait 10 mins.
4. Turn on computer, let all applications load.
5. Turn on R-09.
6. Ensure the R-09 is on the finder screen.
7. Connect the usb cable to the R-09 then to the computer, take no further action.
8. Once "No Name" or "untitled" appears on your desktop, you are connected
9. Click the new icon to access the R-09
10. When you are finished, drag the icon to the trash to safely disconnect.
Again, thanks for using Fix Ya
  • 11,896 Answers
You will have to get a driver just for this device for the computer to recognize it. EDIROL R-09 24-bit WAVE/MP3 Recorder :: Download
Posted on Jan 29, 2009
    Sergeant:
  • 221 Answers
Its the connection loose internally or the usb wire faulty.
Posted on Jan 26, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Try to format the card and it should not contained any other data except audio files.
The CF cards should be reformatted before use, and used only for audio recording. That is because non-audio files stored on the card are not recognised as taking up space on the card. If you reach the capacity of the card, it will stop recording, even though the machine does not recognise the card as being full
  • Rylee Smith
    Rylee Smith Jan 26, 2009
    Also see the link for updating the firmware. You can download the firmware, connect the CF card using a card reader and add the firm ware into the card or try to use USB cable (if it works).
    Sergeant:
  • 378 Answers
Try different usb wires.also connect in another usb socket as the 1 you r trying may be faulty.connect any other device and check out is the usb port working properly.other wise its a defininate problem of drivers as its not compitable to your system of mac.
  • 916 Answers
If the screen is not indicating that it is trying to connect to the computer and the computer does not recognize the device, then the problem has to be the cord try another usb cord and see if that works.
  • 13,433 Answers
Have you tried a PC? you should get a ding dong sound on the connection.
all the documents and updates are available on this page
http://www.roland.com/products/en/_support/om.cfm?ln=en&dsp=0&iCncd=1072
  • Ekse Jan 29, 2009
    Do you have a pc nearby or where you could test it? I personally can't guide you on a mac.
    Plug it into a pc, what happens? is it recognized or do you get a message that the usb device is not recognized or malfunctioned.
    If you get the above messge you most likely have a hardware issue that may require service.
Connecting a USB keyboard to my iMac
Adding the keyboard is one thing but without the correct driver, your pc will not be able to recognise it or make it usable. Check in your device list to see if it shows up and whether it is functioning. If not, you need to download the correct driver from the keyboard manufacturer.
Sep 19, 2017 | Macally Computers & Internet
Imac won't recognize camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Dec 14, 2012 | Canon PowerShot A570 IS Digital Camera
My Ediro R-09 no longer connects to my computer.
maybe the software is corrupted in your computer for the endiro. try to download or the usb cable could also be the problem.
is the memory card removable like in other devices if yes then you can use memory card reader to download.
Aug 29, 2012 | Edirol R-09 Digital Voice Recorder
IMac freezes on start-up and won't unfreeze until I unplug USB-connected hardware.
Mine the same, so don't connect until installation complete, then switch on the or plug in the item
Jun 22, 2012 | Apple iMac Z0GF0005F Desktop
New Lion OS X computer does not recognize DCR PC109
Yes this is a 6 year old OS. Update it to Sierra or at least El Capitan.
Apr 19, 2017 | Sony Handycam DCR-PC109 Mini DV Digital...
Imac suddenly won't recognize 1 TB G-Drive
Hi there mu names Mark.
Lets see what I can do to help you.
Firstly some really obvious things
1 Is the light on the external drive
2 Is the USB/Firewaire cable connected at the Mac and the disk
3 If so reseat it by pulling it out of both ends and replacing
4 Have you tried another USB or Firewire port
something to be getting on with try those and re-post if no fix
regards from England
Mark
Aug 16, 2009 | G-Technology G-DRIVE (90801201) 250 GB...
My iMac says my HP Photosmart 8050 is not connected
the USB port on the back became loose. its common on that series. the ONLY thing you could do, is to take apart the printer (find the screws, they're torx, you'll figure it out while you watch TV) and once you get to the main board, buy a soldering iron at the $1 store and heat up the connections. At most, you may have to buy a little bit of solder for $3 at radio shack. once you do that, the printer works perfectly for a very long time!
Jul 08, 2009 | HP Photosmart 8050 InkJet Printer
My computer doesn't recognize my camera
I discovered that what iMovie says I should do doesn't work. In HELP it says to set the camera to OC CAMERA. At least that's the closest I could come with my Sanyo camera to what it says in iMovie's HELP. Anyhow it doesn't work but if I set the camera to CARD READER instead it worked the way I wanted it to. I'm all set now.
Apr 01, 2009 | Sanyo Video Cameras
My Edirol UA-25 suddenly is not working with Nuendo
Hey, if you're in the UK you can ring tech support on 0208 747 5949 - they're really good.
Have you got the advance switch set to ON on the back of the device?
LC (UK)
Jun 10, 2008 | Edirol UA-25 External Sound System
Edirol R-09 Digital Voice Recorder Logo
370 people viewed this question
Top Edirol Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Edirol Audio Player and Recorder Expert? Answer questions, earn points and help others
