I installed more memory and now my wireless is not working
  • brandon curry
    brandon curry May 11, 2010
    memory should not affet the wireless are you using a desktop or a laptop? althought if it is a laptop then there could be a collision.
  • 112 Answers
Remove the wireless card and then add it.
Posted on Jan 26, 2009
Wireless drivers
If you have just re-installed the operating system without installing the manufacturer's drivers from the CD that should have come with your computer, you do need the drivers. Some viruses disable network capability. Otherwise, the drivers originally installed should be there. Have you verified that the wireless is turned on? Most laptops have either software or hardware switches to turn off the wireless for battery power conservation. Verify that the wireless indicator LED is on. If it is not, find the switch and ensure it is in the on position.
If you are missing the drivers for both wired and wireless networks, go to the Asus support site (on another computer), select Downloads for your computer and download the drivers. Save them to a USB memory device to transfer them to your netbook, then install from there (you may have to copy the files from the USB device to the netbook's hard drive to get the installer to work properly). I would have given you a direct link to the driver, but you didn't tell me what your operating system is.
Dec 07, 2011 | ASUS Eee PC 900HD Netbook
I just erased my whole memory because I got locked out and now my wireless won't work
If it is a laptop the build wireless network driver might not be installed yet and if it is a desktop the wireless card might not also be installed, could you provide me the model and brand of the wireless card or if it is a laptop, could your provide me the model and brand - usually found at the back of the laptop. Or if you do have a cd driver that is labeled as driver try to install it. If you are connected with the Internet Service Providers try contacting them.
Aug 28, 2011 | Computers & Internet
I have bought a netgear wn111 wireless usb adapter and i have no driver cd. As i have bought this to connect my pc to the wireless network, i cant access the internet to download the drivers onto the pc. I...
If you have access to the Internet using a LAN cable, then download the Netgear wireless USB adapter to install the driver. After downloading you can remove the LAN cable.
You can also save the driver from your laptop to an USB memory stick and then install the driver in your computer with the USB memory stick.
May 23, 2011 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
My monitor works fine but there's no picture and the tower is on.
you have a memory problem,
  • If you have two or more memory modules installed, remove the modules, reinstall one module (see Installing Memory), and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer (see Installing Memory).
  • If the problem persists, contact Dell (see "Contacting Dell" in your Owner's Manual).
see more details and your manual here
Apr 04, 2010 | Dell PART NUMBER CARD NTWK PCI TR IBM 16/4...
Install extra memory and a wirelss card in a
The memory slot is most likely in the bottom of the laptop and its hold closed with 2 screws.
Some laptops have the other memory module under the keyboard, if the other memory module is not in the bottom of the laptop, you would have to unscrew the screws from the bottom of the laptop that are under the keyboard, those screws may be marked with K/B (meaning Keyboard screws)
Then you may have to remove the plastic cover from the top of the keyboard which is between the display and the keyboard, in most cases this is hold in place with just plastic clips, you can remove it with a small flat screwdriver starting at the display hinges and then working your way slowly to remove it completely, if it really resists alot, check for screws in the bottom and the nearby areas and unscrew them, we don't want to ruin it.
Then you should be able to unscrew the rest of the screws on the keyboard and take it up, and you should be able to get to the 2nd memory module.
About the wireless card, you can use a USB, a PC card or possibly a internal card if the laptop has room and a connector for it inside, I would recommend you go with either a USB stick or a PC CARD, take the laptop with you to a local shop to find out which one would be the best option for your laptop.
let me know if you need furhter assistance.
Sep 11, 2009 | Compaq Evo N610C Notebook
Compaq evo n610c
yes i solved the problem. Remove the wireless lan. Start the computer go to regedit hkey_local_machine/software/Compaq Wireless LA delete it and restart. download SP23031 search on google and run without wireless lan W200. Restart with the card installed it will configure itself.
Jun 24, 2009 | HP Compaq Evo n610c Notebook
Dell Latitude D610 -- Windows XP Professional
the freeze up problem is due to the limited HHD space or memories. please check your HHD and see how much free sapce you have, and check your memories. the base system came with 256MB, which is too little for anything to work porperly. for you to connected to teh wireless, you should have minimum 1GB of memories. some people may disagree with me, but that is what I found to work better, if you have more than required memories.
Feb 11, 2009 | Dell Latitude D610 Notebook
My Linksys Wireless-G Notebook Adapter V2.0 is no longer working
Try un-installing the wireless adapter, and then reinstall it back. If this does not work, check out the configuration in both the router and in the computer. You will have to connect the computer directly to the router to check out the router's configuration.
It is also possible that the wireless adapter has failed. The only way to verify that is to try another one.
Jerry G.
Jan 22, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
